Results 1 to 2 of 2
Thread: 72 ride height question, opinions sought.
    trying to DIY tune the suspension of my 72.
    i'm equipped with stock torsion bars, but installed SC control arms
    FRONT: IIRC stock height is about 210 mm, my fortuitous setting while assembling is 155 mm.
    too low? Bump steer problems? i did not install a bump steer spacer set. it looks pretty nice.
    REAR:Stock is 12 mm, my settings L: 17mm, R: 10 MM
    aside from trying to even things up, what should i shoot for?
    thanks in advance
    bob moglia
    '72 E sunroof coupe
    Jul 2012
    Claremont,CA
    rob,
    if its too low you rear tires would camber in.
    2cents
    porschegal
    CEO of the Best early 911 parts store in Southern California
    www.Schnellautosports.com
  1. Ride Height
    By misterc in forum Technical Info
    Last Post: 03-22-2013, 12:42 PM
  2. Ride height
    By EA911 in forum Technical Info
    Last Post: 08-14-2009, 09:58 AM
  3. Ride Height
    By boxster03 in forum Technical Info
    Last Post: 09-30-2005, 01:03 PM
  4. Ride Height
    Last Post: 05-21-2005, 04:21 AM
  5. ride height
    By scargo70 in forum Technical Info
    Last Post: 02-22-2004, 02:02 AM
