Results 1 to 10 of 12
Thread: Parts ID help - door check straps
    I recently purchased these to fit on my rally car, as they looked pretty cool
    Can anyone advise their original fitment ?, they look OE from the buckles used, but I have not seen any fitted, I guess they are sixties period...
    Look forward to suggestions
    Phil Hindley
    Tech 9 Motorsport
    United Kingdom
    www.tech-9.co.uk
    Early S registry membership #2207
    65 911 Racecar
    82 911 SC Coupe
    91 944 Turbo
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Phil, I don't know what you have there, but they surely are purpose built.
    Here is a set that I've had for many years; solid rubber and very burly.
    RGruppe #183
    Jan 2011
    DFW TX
    Not sure if it's obvious from the pictures but they are leather, not rubber, but interesting similar markings where the two pieces are pressed in the central area comparing with Jens set
    Phil Hindley
    Tech 9 Motorsport
    United Kingdom
    www.tech-9.co.uk
    65 911 Racecar
    82 911 SC Coupe
    91 944 Turbo
    Aug 2003
    vahmont
    Quote Originally Posted by M_deJong View Post
    Paint 'em black.
    RGruppe #183
    Door check strap
    The door check straps in the photos were from Gebr. Happich GmbH, Germany. See below. These were sold to be used on trucks and busses.
    Amazing you found that, yes, that is definitely the strap, as it has the part number and the weight rating, as detailed on the document
    Thank you for taking the time to respond
    Phil Hindley
    Tech 9 Motorsport
    United Kingdom
    www.tech-9.co.uk
    65 911 Racecar
    82 911 SC Coupe
    91 944 Turbo
    The ends look familiar like the luggage strap brackets on a 356 or early 911. Do the two straps form a "cradle" for a 356 cabriolet top assembly when it is in the collapsed position?? -Ed Anspach
    Quote Originally Posted by Jens View Post
    Aug 2003
    vahmont
    Phil, are yours rubber with textile reinforcement as in Hunter's spec sheet?
    RGruppe #183
    Aug 2003
    vahmont
    Ed, I don't really know about a 356 application.
    I will use these door stops on my white car when I finally do the door panels and the rest of the lightweight interior.
    RGruppe #183
  1. Door check does not hold door. Suggestions?
    By '70 Le Mans in forum Technical Info
    Last Post: 09-14-2022, 03:53 AM
  2. Door straps
    By Merv in forum Technical Info
    Last Post: 09-21-2013, 12:34 PM
  3. Replies: 1
    Last Post: 12-02-2011, 10:18 AM
  4. Replies: 9
    Last Post: 08-29-2010, 06:07 PM
  5. FS: Door check rod
    Last Post: 10-25-2009, 08:40 AM
