Results 1 to 7 of 7
Thread: Foglights and other electrical gremlins - 73.5 911
    Junior Member
    Jun 2012
    Austin TX
    Hi All
    The 73.5 911 is coming back to life:)
    My wife and I had it on the freeway this weekend and it was really smooth at 60 in 4th. I believe the shift linkage needs adjusting - shifting into 5th the rpms jumped to where I think it was in 3rd gear?
    Appreciate comments on that issue.
    I'm currently working through a few electrical issues with a 73.5 911 that I'd appreciate your thoughts on.
    I've had the alternator rebuilt and replaced the VR with a solid state version.
    This cured alt light on always initially. This morning however, I noticed that the alt light glowed weakly at idle - this is the first time I have seen this since replacing the alternator/VR??
    Foglights:
    Engaging the FL switch I don't get lights or the red indicator on the switch to light.
    If I jump power from fuse 1 directly to the FL fuse (8 I think) I get lights on - so bulbs are good.
    The FL relay appears to be OK: I swapped it for the horn relay and the horn works.
    Turn signals/fuel gauge:
    With turn signals on, the fuel gauge bounces in sync (sometimes).
    Ignition switch:
    I have to have the key in just the right position to energize the starter.
    Does this indicate the key is worn, or the switch is going south?
    Appreciate suggestions.
    Charles
    Your headlight have to be on for the fogs to come on. You probably need a new ignition switch.
    Make sure all your grounds are clean and in good condition.
    I've heard that the radio suppression condenser may cause the alt light to come on with solid state conversions. I have no direct experience with this.
    check the shifter coupling under the panel behind your seats. This is probably worn and should be rebushed then realigned.
    Sorry for the order of the answers.
    Jul 2012
    Claremont,CA
    the replacement switch you want is part number
    964 613 012 00
    We just replaces ours.
    thanks
    Porschegal
    CEO of the Best early 911 parts store in Southern California
    www.Schnellautosports.com
    Jan 2011
    DFW TX
    Shifter - readjust. If still a problem replace coupler bushings and maybe the round bushing in the tunnel and cup at shifter.
    Alternator - ok in my experience if the light glows dimly at low idle. If it glows brightly or stays on >1500 rpm then there is a problem.
    Fuel gage - ground problem - clean all the grounds behind the instruments
    Use a voltmeter hooked up at the battery to check your charging rate both at idle and 2,000 RPM. If too low at idle the turn signals may flicker because of the voltage draw. The fog lights only work with the LOW beams on. AS already mentioned, grounds can also be the culprit, hopefully you attached the ground strap to the back of the alternator when you installed it, also check the ground strap from the transmission to the bulkhead. Are you familiar with the shift adjustment procedure?
    Junior Member
    Jun 2012
    Austin TX
    Thanks for all your suggestions.
    I'll check grounds and look into adjustments for the shifter.
    thanks!
    c
    Junior Member
    Jun 2012
    Austin TX
    Hi All
    Another gremlin has risen to the top of the list.
    The car has had cold-start issues since I first got it running, but once it warms up it runs smooth, and starts instantly when hot.
    This weekend I could not get it to start and idle. It fires, runs very rough and dies. Sunday it would not start at all.
    I have not yet replaced the ignitiion switch.
    I suspect the cold-start circuit?
    The car has MFI with a cold start solenoid atop the fuel filter.
    Ideas on trouble shooting this issue?
    Charles
  1. electrical gremlins - where are the grounds?
    By Boulder Bob in forum Technical Info
    Last Post: 07-15-2014, 02:17 PM
  2. FS original 69 911 foglights
    By dallaseurocars in forum For Sale: 911 Parts
    Last Post: 02-18-2010, 02:20 AM
  3. Electrical Gremlins
    By lwalwa in forum Technical Info
    Last Post: 10-22-2006, 10:50 PM
  4. Hella 128 foglights?
    By ttweed in forum Technical Info
    Last Post: 04-06-2001, 12:19 PM
