Results 1 to 7 of 7
Thread: FS: rebuilt MFI pump and enrichment device
    Dec 2004
    SE Michigan
    MFI Pump w/ Supertec Enrichment Device: SOLD
    Plug and play.
    Supertec rebuilt/recalibrated pump
    T spacecam (see Pelican or call Henry for his position on why this is fine, not looking to debate anyone in this thread)
    solenoid removed
    sealed pump, added breather (if you want to go back to the original set up, Henry had boxes of old parts at the time)
    Supertec enrichment device
    ONLY looking to sell outright. No trades.
    Bill G.
    EarlyS #718 | RGruppe #437
    calibrated for what displacement?
    Dec 2004
    SE Michigan
    Henry built it for a 2.8L with the T cam per above.
    Here's one of Henry's threads discussing the whole space cam issue. You can see at the end of this thread I sent this pump to him in 2006. There's two other good threads on this topic on The Bird you can find.
    Bill G.
    Bill,
    So would the pump still function properly for a stock 2.4T MFI car?
    Dec 2004
    SE Michigan
    Should be able to adjust rack when you set it up. I would give Henry a ring and ask him if you are interested.
    Bill G.
    Hi Bill
    sent you a pm
    regards
    Tony
    Quote Originally Posted by 911scfanatic View Post
    MFI Pump w/ Supertec Enrichment Device: $1550
    solenoid removed
    Looking to sell outright, or trade for:
    S pistons
    40IDS carbs
    S cams
    SWB Webasto heater (complete setup)
    anything else that might be interesting
    ...for my '68N
    Dec 2004
    SE Michigan
    Starting to clean out the garage attic...
    Bill G.
  1. Bosch 2.0E MFI Pump - Rebuilt
    By jbell959 in forum For Sale: 911 Parts
    Last Post: 03-10-2010, 07:37 PM
  2. 2.0S Bosch MFI Pump (Rebuilt)
    Last Post: 03-05-2010, 07:23 AM
  3. Rebuilt MFI fuel pump
    By Frank Beck in forum For Sale: 911 Parts
    Last Post: 07-09-2008, 11:07 AM
  4. Replies: 7
    Last Post: 05-17-2007, 01:40 AM
  5. Rebuilt Oil Pump?
    By Fritz A. Ficke in forum Technical Info
    Last Post: 11-28-2004, 06:31 PM
