Results 1 to 10 of 11
Thread: WT Swap PMO Manifold
    Port Macquarie, Australia
    Hi Guys
    I have a set of PMO manifolds 40mm to 32mm port. I was going to just machine these open to 36mm for my RS spec engine, but thought I'd check to see if anyone has a set of PMO manifolds already set up for RS specs but need a set of 32mm?
    Just a straight swap?
    John Forcier
    EarlyS #1987
    Restoration Saga
    I'm your huckleberry. I think I may have something. I will check tomorrow. What port size do you need?
    -Marco
    TLG Auto: Website
    Hi Marco
    My heads are ported to 36mm (RS replica engine).
    Thanks for looking
    John Forcier
    EarlyS #1987
    Restoration Saga
    Quote Originally Posted by Fishcop View Post
    Hi Marco
    Thanks for looking
    I'm heading in to the shop with my camera tomorrow, so I'll snap a few photos if I have what you need. PM me with your email address just in case...
    -Marco
    TLG Auto: Website
    Feb 2007
    Thousand Oaks, CA
    I've got a pair of tall 40mm PMO manifolds with 38mm ports.
    Tom Ching
    69E Burgundy
    Hi Tom
    I think the 38mm will be too big for my engine - the intake ports are definitely 36mm, so it would create a bit of a 'step'...
    John Forcier
    EarlyS #1987
    Restoration Saga
    No dice, John. They're 38s, too.
    -Marco
    TLG Auto: Website
    I have heard that a step of 2mm is good by a few veteran builders and richard parr(pmo)
    Ok but the other way around ,DOH!
    May 2006
    CT
    I have stock S manifolds with 36 mm ports
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  1. FS manifold for weber 40
    By advtracing in forum For Sale: 911 Parts
    Last Post: 11-12-2012, 01:24 PM
  2. Early S manifold question
    By Baron in forum General Info
    Last Post: 10-23-2012, 11:57 AM
  3. Weber Intake Manifold
    By Kilgore Trout in forum Technical Info
    Last Post: 07-27-2009, 05:32 AM
  4. Weber 40 IDA's, manifold, K&N
    By JHunter in forum For Sale: 911 Parts
    Last Post: 02-28-2008, 04:02 PM
  5. Uh oh, Weber manifold cracked!!
    By berettafan in forum General Info
    Last Post: 03-30-2007, 08:39 AM
