Results 1 to 2 of 2
Thread: SWB caliper bracket question
    Aug 2010
    Colorado
    Is there a left and right? Or are they the same and you flip them over? Does anyone have a picture of a factory S bracket?
    Chris
    There is only one Part Number in the PET and they would be the same for the 911S as the calpier mounting centres didn't change until the Aluminium Caliper in 1969 and this used the later style strut.
    I don't believe the plate changed with the vented disc as the spacer added the width outboard of the plates.
  1. S Caliper question
    By motogman in forum Technical Info
    Last Post: 04-26-2013, 12:22 AM
  2. Any Vintage Racers here? 911S Alloy caliper question.
    By Martin Baker in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 04-01-2013, 09:06 PM
  3. Caliper Fit
    By chicagobreezz in forum Technical Info
    Last Post: 04-01-2009, 11:29 AM
  4. Caliper Bolt/Washer Question
    By Brad Davis in forum Technical Info
    Last Post: 03-23-2009, 12:32 PM
  5. SWB fog bracket question
    By jtkkz in forum Technical Info
    Last Post: 08-20-2008, 07:04 PM
