Thread: Spacer and o-ring
    Spacer and o-ring
    On my 71 911t they show a spacer and o-ring on the front strut before you put the hub and bearing assy on.my car does not have them.what are their purpose and should i put them on.
    Thanks david
    you need them. It is a spacer and is where the wheel bearing seal rides. gled
    Jan 2011
    DFW TX
    Are you sure they aren't there? The spacer looks like an integral part of the spindle and the hub seal rides on its outside diameter. The inner bearing seats against its face.
  1. Spacer Ring
    By merbesfield in forum Technical Info
    Last Post: 11-10-2013, 03:21 AM
  2. Steering wheel spacer ??
    By Greg D. in forum Technical Info
    Last Post: 05-23-2012, 06:51 AM
  3. L-Caliper Spacer Kit
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 06-05-2010, 10:56 AM
  4. shims and spacer, did the factory used them
    By freezing14 in forum General Info
    Last Post: 11-01-2008, 07:11 PM
