Thread: 2.0 motor advise
    Senior Member bobm's Avatar
    Aug 2011
    Northern California
    2.0 motor advise
    My 1966 2.0 motor is apart and ready to put back together. Mechanic say's everything looks good only thing of concern is the intermediate shaft "bearing" surfaces. He say's the earily 2.0"s did not have an actual bearing, they rode on the case
    He feels this surface may be getting close to the limit and may look into having the case bored and put in the later bearing plates. He said that mine left alone may last a long time but asked me to ask the community for your thoughts.
    Has this been a problem with these earily motors. Is his idea of the later bearing a good fix. I checked with our local machine shop (356) and he has not done this for a 911. Your thoughts/ideas are This is my first 911 and looking forward to driving this car.
    Bob
    Nor Cal
    Bob,
    The usual shops, Ollies, Competition Engineering etc. can cut your aluminum case for the later bearings. This is about a $700 modification. It's a great fix, it's just expensive.
    Have you done the oil bypass mod, piston squirters and the rest of the updates? Might as well do these while it is apart.
    What are the precise dimensions of your intermediate shaft bore and shaft? "May be getting close to the limit" well how close and what limit? I would start with that. Then there's the issue of how much backlash in the intermediate shaft gears, that's another measurement. In order to advise you on these things your mechanic must have made the measurements, so give him a ring and ask him what they are.
    When I rebuilt '065's motor the bore was fine so I left it. The mag case motors wear a great deal in this area. Not so much the aluminum case.
    Oct 2010
    Southern Ca.
    I would recommend new or have Ollies drill more holes in your spraybars .
  1. Price advise !!? 69 911 T
    By LV911 in forum General Info
    Last Post: 02-22-2014, 08:07 AM
  2. Advise on buying a 2.7 RS?
    By mikaeln in forum General Info
    Last Post: 09-05-2010, 12:54 AM
  3. Need Value Advise MFI Stacks
    By chuix_21 in forum For Sale: 911 Parts
    Last Post: 07-18-2008, 02:39 PM
  4. Advise
    By platas in forum For Sale: 911 Parts
    Last Post: 07-09-2005, 09:37 AM
  5. please advise me!
    By d_o_n_k in forum General Info
    Last Post: 02-13-2004, 11:18 AM
