Results 1 to 10 of 12
Thread: Sump Plate with Drain Plug...Where?
    I'm about to change oil in my 1971 914-6 and decided to look for a sump plate with a drain plug installed. I did a search and no matches appeared. I'd appreciate any help finding one.
    Thank You.
    Early 911S Registry member#775
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    Is this what you are looking for?
    http://www.pelicanparts.com/cgi-bin/...35%2D%38%33%29
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
    dave29...I have used stock ones including the screen available...
    Apr 2011
    N.Calif., south of SF
    Try this (be sure to choose from the drop down list the one with drain bolt)
    http://www.sierramadrecollection.com..._detail&p=5071
    haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    It all depends on what type of oil pump you're using...
    -Marco
    TLG Auto: Website
    Thanks everyone. I appreciate your help. I decided to go with the the plate from Sierra Madre. It's basically a stock plate with a threaded hole for the drain plug. Next question is do I keep the screen in or remove it once I install the new plate?
    Thanks again.
    Ok......so I just received a call from Sierra Madre. They do not have the plates in stock and don't know when they will get them. What i'm looking for is a stock factory plate with the drain plug thread and the drain plug itself. Does anyone have these??
    Thank you
    Apr 2011
    Try Aase Sales http://www.aasesales.com/products/id-num-102100 they show the plate, you would need to get the gasket and the magnetic drain plug.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    as posted above....that is what I have....OEM cover, plug, screen....here is a pic...$37 shipped us48
    I'll take it. Can you PM me your contact info ??
    Thanks much.
  1. FS: Engine Sump Plate 930-101-9??-00
    By MoparBoy72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-02-2014, 06:07 PM
  2. Sump Plate with Drain Plug...Where?
    By dave29 in forum Technical Info
    Last Post: 09-24-2012, 06:52 AM
  3. FS: Sump Cover W/ Drain Plug for 930 Turbo Pump
    By 76911S in forum For Sale: 911 Parts
    Last Post: 01-07-2011, 02:14 PM
  4. Wtb:engine sump plate
    By 71-911T in forum For Sale: 911 Parts
    Last Post: 08-05-2009, 09:00 AM
