Thread: '72 engine compartment sound mat
    I did a search, read the threads...more confused than ever after on line shopping
    the engine sound mat on my '72 Targa has finally fallen..bad timing too
    Not only are the choices in weight, 1lb to 4lbs to 6lbs but in material, foil vs. foam..Is foil the way to go? Not a fan of the way it looks? Also sound dampener vs. soundproofing
    Bottom line, what has been working best?
    I read on Pelican that people have installed the pad with the engine still in, using magnets to hold it in place. Anyone here try it? I REALLY don't want to pull the motor
    links from 3 of the more common vendors used
    http://www.pelicanparts.com/cgi-bin/...FILTER_TOOL=ON
    http://stoddard.com/shop/shopdisplay...ound+Deadening
    http://www.sierramadrecollection.com..._detail&p=8614
    Not supposed to be this difficult, maybe I'm trying too hard..or just bored and looking at too many places
    [SIGPIC][/SIGPIC]
    Ray Crawford
    Early S Registry #271
    R Gruppe #255
    '70 911 S Coupe 2.9 w/MFI Twin Plug "Flairs n Chairs"
    '72 911 S Targa 2.4 w/MFI
    Ray,
    I went with the lightweight 'skinned' foam and never looked back... I did put mine in with the engine out.
    However I would think the lightweight pad wouldn't be much trouble with the engine in.... air cleaner and all breather hoses off of course....
    Hope this helps
    engine sound pad
    We used to use the official Porsche pad, but I got tired of seeing fall down two years later because the foam comes apart (not a glue failure) We started using the closed density foam from that comes precut from Appbiz. It NEVER falls down. And I don't thing I've yet been gigged on it in concours. You can install it with engine in, but dropped down a bit in the rear by unbolting the crossbar and lowering the engine slightly on a jack. Put protectors over the upper shock bolts, and then fit the pad so that it will line up properly with the retaining tabs on top of the engine bay, then let the pad fall down on top of the engine but with the pad still stuffed into the cross member. Wear latex gloves, spray adhesive about 6-7 inches up the bulkhead and pad, stick that part only, check for fitment in the tabs, keep slowly working your way up the bulkhead. When you're spraying and sticking the final few inches the pad should line up in the tabs evenly. Big thing is make sure you have the pad exactly where you want it before any sticky stuff gets started.
  1. Sound Dampener for Engine Compartment
    By Haasman in forum Technical Info
    Last Post: 07-22-2012, 06:07 PM
  2. WTB correct engine compartment sound pad for 72
    By Terry Forland in forum For Sale: 911 Parts
    Last Post: 02-09-2012, 11:55 AM
  3. Early SWB engine compartment sound pad
    By Neil '67 911S in forum For Sale: 911 Parts
    Last Post: 10-01-2011, 06:30 AM
  4. Engine compartment sound pad
    By 71six in forum Technical Info
    Last Post: 06-28-2011, 04:24 AM
  5. WTB Engine Compartment Sound Deadner
    By 69S-S/R in forum For Sale: 911 Parts
    Last Post: 04-24-2011, 11:48 AM
