Results 1 to 10 of 11
Thread: Porsche 911 1967 Floor pan hard to find part ?!
    Hello Folks,
    I am wondering if it would be hard to find this part ??
    It's the part which is blocking the hole.
    It is fitted to a 67 911.
    Thanks for your feedback
    I think there is currently one on ebay. If not any longer, they are available.
    RIchard
    Thanks Richard
    How do you call it ??
    Xcuse my English
    Chris
    front pedal area (and then I also know if I understood your quest correct )
    http://www.restoration-design.com/Me...e=911-CHA#P218
    You are a star Thanks
    I have checked and wrong part the one i looked for is on the passenger food area and round.
    Thanks anyway
    Than you need the pedal area + passenger floor pan or front floor pan (OEM Porsche) depending on which supplier you use. Bottomline the sheet metal that you need is available.
    Richard
    Oct 2010
    Stockholm/Sweden
    I believe Froggy is referring to the block of for the hole that goes up to the smugglers box.
    From what I know, it´s just a round piece of metal with a rubber gasket(?).. A hole in it with a bolt through applies pressure on a bracket that holds it against the floorpan.
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Froggy---do you mean one of the flat metal plugs that are/were glued (caulked, actually) into the floor pan holes in various locations? If so, I believe these were installed after the body shells were prepped for paint --- I think the holes were used as drains.. The aftermarket floor pans don't have holes--just dimples as I recall. In any case, these are just roughly 2" sheet metal circles....I made mine out of aluminum and used urethane caulk to glue/seal them in place before I applied the rubberized undercoat.....
    I would agree on this
  1. Need to find a part for a 1971 Porsche 911E
    By VaporiZe in forum Technical Info
    Last Post: 05-13-2013, 11:52 AM
  2. 1967 Porsche Targa part
    By dougfree in forum For Sale: 911 Parts
    Last Post: 03-22-2010, 05:41 PM
  3. FS Early fog switch, hard to find!
    By fishman7 in forum For Sale: 911 Parts
    Last Post: 10-19-2009, 02:56 PM
  4. That hard to find part
    By Stephen T in forum General Info
    Last Post: 01-15-2009, 02:53 PM
  5. hard to find automotive items!
    By EARLY911ZOO in forum Off Topic
    Last Post: 09-05-2008, 07:53 AM
