Thread: FS: Shortened G50 gearbox and conversion parts package
    I recently purchased a running and road-tested 3.2 drivetrain and have decided to part with the G50/5-speed gearbox (open dif) and related conversion pieces as a package. There were no docs or working speedo on the vehicle, an '81 SC with a 959 body kit. However, all is fine. Shifts good; synchros good.
    This gearbox (87-89) has been "shortened" (Patrick MotorSports?) to fit pre-964 911s with very minor modifications to clear the torsion bar tube.
    - G50-01 5-speed gearbox with aluminum gearbox mount, clutch slave cylinder/flex hose and elec. speedo sensor. From factory specs, the gear ratios are as follows:
    1st, 3.500:1
    2nd, 2.059
    3rd, 1.409
    4th, 1.125
    5th, 0.889
    Final drive is 3.44:1
    Other matching package parts include:
    - Starter ring gear
    - Bosch starter motor
    - Sachs 240mm Turbo racing aluminum pressure plate (11.95 lbs). Sachs Race Engineering, part no. 88 3083 999 574. TYP GMFZ 240
    - Turbo clutch disc w/TO bearing.
    - 3.2/G50 conversion 240mm flywheel/pilot bearing. Clutch/flywheel package looks relatively new (excellent condition).
    - G50 Shifter assy
    - G50 Shift tube
    - G50 Shift coupler
    - G50 pedal assy. with clutch master cylinder
    - Dual fluid reservoir w/mount bracket for brake and clutch circuits
    SOLD.
    Sherwood
    Note:
    Flywheel not in the group photo, but included
    Add'l pics in the following posts
    Add'l images:
    more images:
  1. FS: OE 911 parts for 110mm 5 bolt conversion
    By Slcarr in forum For Sale: 911 Parts
    Last Post: 08-15-2013, 04:16 PM
  2. FS: g50 'shortened' to fit pre-964 911s and all parts.
    By Louie in forum For Sale: 911 Parts
    Last Post: 06-06-2013, 04:25 PM
  3. 911R parts package
    By andyjboy in forum For Sale: 911 Parts
    Last Post: 10-22-2009, 02:46 PM
  4. 73 RS Conversion Parts
    By Rennman in forum For Sale: 911 Parts
    Last Post: 01-01-2008, 05:32 PM
  5. 73 RS Conversion parts
    Last Post: 10-14-2007, 07:14 AM
