Results 1 to 1 of 1
Thread: Weber IDTP to IDA conversion
    If you suffer a flat transition with your IDTP carbs then there are a couple of ways to deal with it:
    1. Install new throttle plates with a modified ellipse angle to help cover the first transition hole (which is partially exposed at idle on these carbs) and to install smaller idle air bleed jets (not a standard replacement jet)
    2. Have the progression holes reworked to have the progression of IDA carbs and (again) replace idle air bleed jets with IDA sizes
    Here is a picture of what the second option looks like after replacement:
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
  1. FS: Complete set of Weber 40 mm IDTP carbs
    By Porsche-nut in forum For Sale: 911 Parts
    Last Post: 01-15-2014, 04:20 PM
  2. Power brake conversion / de-conversion (1973 2.4E)
    By obrut in forum Technical Info
    Last Post: 12-13-2012, 02:18 AM
  3. CIS to Weber conversion question...
    By joeblow in forum Technical Info
    Last Post: 08-04-2010, 02:42 PM
  4. FS:Weber 40 IDTP
    By OliveR in forum For Sale: 911 Parts
    Last Post: 04-21-2009, 12:01 AM
  5. Feeler: Weber 40 IDTP carbs
    By Dan in RI in forum For Sale: 911 Parts
    Last Post: 03-29-2009, 08:44 AM
