Results 1 to 2 of 2
Thread: gap/dwell setting question
    1972 911 E MFI fresh rebuild.
    I set the gap with distributor out, exactly .014" as spec.
    the dwell is < 25.
    i know to increase dwell you must decrease gap.
    how low can i go with gap setting?
    or is that dwell so far off my dwell meter is not correct?
    thanks
    __________________
    bob moglia
    '72 E sunroof coupe
    Ignore my earlier comment but do close the points down until you are at the low end of the dwell specs.
  1. setting dwell, unusual question
    By robmog in forum Technical Info
    Last Post: 09-18-2012, 05:48 PM
  2. What is the effect when dwell angle is too large?
    By caproader in forum Technical Info
    Last Post: 10-03-2011, 12:25 PM
  3. tach/dwell meter
    By Kilgore Trout in forum Technical Info
    Last Post: 03-20-2011, 04:04 PM
  4. dwell vs timing
    By 356robo in forum Technical Info
    Last Post: 09-19-2009, 08:42 AM
  5. Points Gap, dwell & timing?
    By pwd72s in forum Technical Info
    Last Post: 08-10-2003, 05:17 PM
