Thread: Weber IDA rebuild - any detailed description out there
    Feb 2011
    Surrey, UK
    I have a pair of standard early 911 Webers IDA's that are in bits. They came with a standard rebuild kit, and I look to have most/all of the parts, many of which have been re-coated.
    So now I need to put them back together.....has anyone found a detailed rebuild thread or link anywhere on the net, or a book that describes the rebuild in detail? Also I will need a few new parts, so a link to a supplier would be good, especially a European/UK one.
    Mick
    Jan 2003
    UK
    Mick - for parts stockists inthe UK & Europe I've used:
    Webcon (UK) - http://www.webcon.co.uk/shop
    Eurocarb Ltd (UK) - http://www.dellorto.co.uk/merchandis...tsectionID=100
    Mittelmotor (Germany) - http://www.mittelmotor.de/webshop/englisch/mm.htm
    As for a rebuilding guide there is a lot of useful information on Paul Abbott's website:
    http://www.performanceoriented.com/technical.htm
    Andy
    Early 911S Reg #753
    R Gruppe #105
    http://www.piercemanifolds.com/product_p/99000.700.htm
    this is the factory book, pretty detailed, in German and English.
    See also this thread of mine from several years ago
    http://forums.pelicanparts.com/911-e...annotated.html
    I found this page to be useful. The photos enlarge if you click on them.
    http://home.comcast.net/~ekchuah/Weber.html
    Not used this company but they might be of some help.
    http://youroil.net/weber_carb_parts.html
    Regards, Mike.
    Feb 2011
    Surrey, UK
    Thanks to all - I think I can rebuild them using that wide range of info.
    Mick
  1. weber carb rebuild
    By TZombek in forum Technical Info
    Last Post: 11-07-2012, 05:21 AM
  2. Weber rebuild issues
    By fast911s in forum Technical Info
    Last Post: 07-30-2010, 01:48 PM
  3. Weber Rebuild - girlfriend pic
    By Kilgore Trout in forum Technical Info
    Last Post: 08-11-2009, 05:11 PM
  4. Weber rebuild questions
    By Davz912/911 in forum Technical Info
    Last Post: 03-19-2007, 12:52 PM
