Results 1 to 7 of 7
Thread: Early SWB floor heater slides question
    Apr 2011
    N.Calif., south of SF
    Were the 65-66 early 911's heater slides beige or black?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    black plastic slider
    silver cad base
    Apr 2011
    Interesting, what I thought. I just purchased from a member a set of NOS with 911 part numbers, the sliders are beige. Later cars? 356s?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Mine are black - I've been thinking of removing the bases to have them replated, but they are cap riveted in. I've never messed around with cap rivets, so am hesitant to dig in right now.
    BTW, can you post some pics of the beige slides. I'd be curious to see them.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    LOL, heat the plastic up with a hair dryer and GENTLY ease the slides over the bumps. Blast and plate away. You can achieve a nicer finish doing this than buying the new or NOS ones. The black plastic in both cases is a pretty rough molded part.
    Good idea - thanks. I'll assume then that getting new rivets in place isn't a huge issue - McMaster must have some reasonable replacements.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    You shouldn't need to remove the rivets. If you have a set of slides that requires you to remove the rivets due to corrosion, I would source a new set.
  1. FS: SWB Heater Slides
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 03-22-2014, 06:58 PM
  2. FS: SWB Heater Slides
    Last Post: 11-23-2013, 03:10 PM
  3. FS: SWB Heater Floor Slides
    By jhora in forum For Sale: 911 Parts
    Last Post: 03-06-2011, 06:30 PM
  4. SWB Heater Slides Restored
    Last Post: 09-26-2010, 01:03 PM
  5. Heater Vents / Slides Restored
    Last Post: 04-21-2010, 02:58 PM
