I have a pair of SWB fenders off a 1967 912. Same as 911.
DS fender is in remarkable shape. Only corrosion on the TS bucket. Lower dogleg and upper corner behind filler neck is VERY clean. No rust in headlight bucket.
PS fender needs work but is fixable. vertical fender support is perfect. No rust in upper mounting corners or headlight bucket. rust hole in lower dogleg and TS bucket. sheetmetal under horngrill needs to be straightened.
$600 shipped. Will pack thoroughly.
