Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Help with Michelin TB Fit to Fuchs
    Port Macquarie, Australia
    Hi All
    Question for the wheel/tyre gurus... Harvey?
    I have a set of Michelin TB15 in 270/45 (23/62) and 295/40 (26/61) 15" of course - they were on 9 and 11 inch fuchs. My car has RS rear flares and standard front guards and normally runs 7 and 8 inch fuchs. I know there is not a hope that rear 26/61 tyres will fit the fuchs, but I'm pretty sure I can get the smaller 23/62 on my rear 8" fuchs leaving me with a set of 26/61 TBs to barter. My question is two-fold...
    1. Will the 610mm/24" diameter 23/62 fit well enough on the 8" fuchs and not foul the rear guards?
    2. Is there a narrower Michelin TB available to go on my 7" front fuchs and will they fit standard guards without fouling?
    Thanks for any assistance (and photos )
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
    Matt Hart
    matthartcreative@instagram
    RHD 914
    1980 911SC (sold)
    69' T (sold)
    Early 911s reg # 994
    Aug 2009
    Germany HG
    What sizes would fit quite well on RS flared cars are 18/60s front and back. The 23s will be too wide as these are equivalent to 270/45s.
    Here is a picture I have taken of an RS with 18/60 all way round:
    Cheers,
    Christian
    RGruppe #649
    Early911S #1788
    May 2005
    Oroville, CA
    I agree with Christian. The specs look good and they fit on his car.
    The only vintage tires that we have put on the RS flairs are the Avons.
    Christian, how much camber and how close is the outside lip on the fronts?
    I may try a set on my car....
    The 23/62 and the 18/60 are the tires we put on Joey's ST with 8&9s....and much bigger flairs.
    That is also the size combo that we put on 9&11s. Yes, I know they are stretched for the wheels but they look and work very nice.
    H
    Thank you Gents.
    It would appear what I have will be just too wide for my application - I certainly don't want to blister the new paint on my guards
    John Forcier
    EarlyS #1987
    Restoration Saga
    Hi Gents
    I've sourced one pair of the 18/60 15 locally which will go on my 8" rear wheels. I'm about to purchase another pair and am wondering on your thoughts relating to using the 15/60 15 on the front 7" fuchs instead... will they be too "skinny" looking? http://www.longstonetyres.co.uk/page...elin-tb15.html
    John Forcier
    EarlyS #1987
    Restoration Saga
    Aug 2009
    Germany HG
    John,
    As mentioned on the Pelican thread I spoke to longstone regarding the 15/60-15 - these seem to be from 2004 as this was the last time Michelin has produced them. So perhaps you should talk to them on the production date.
    Christian
    RGruppe #649
    Early911S #1788
    Hi Christian
    You're right that the 15/60 are pretty much 2004 code only, however I won't be tracking my car and (from all accounts) the tyres have been warehoused and stored correctly. Longstone are also offering free delivery worldwide at the moment, so they remain attractive to me!
    Any thoughts on the size? I think the alternative sizes are 215/55-15 for the rear and 170/65-15 for the front with 614mm and 602mm OD respectively. I think this makes them awfully close to the original RS sizes
    John Forcier
    EarlyS #1987
    Restoration Saga
    I run 18/60 TB 15's on 7J&8Jx15 Fuchs
    The tyres sit nice on the rim, and plenty of mechanical grip
    Phil Hindley
    Tech 9 Motorsport
    United Kingdom
    www.tech-9.co.uk
    Early S registry membership #2207
    65 911 Racecar
    82 911 SC Coupe
    91 944 Turbo
    Thanks Phil, wonderful shots!
    Well that's probably sorted it for me then - I'll run 18/60 on all four corners.
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
  1. FS: 16x6 Polished Fuchs with Michelin tires
    By Rolly in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-16-2013, 11:33 AM
  2. FS: 16x6 Polished Fuchs with Michelin tires
    By Rolly in forum For Sale: 911 Parts
    Last Post: 02-11-2013, 04:56 PM
  3. 8&9/15 Fuchs and relevant Michelin TB15 sizes
    By speedmat in forum Technical Info
    Last Post: 10-03-2012, 06:02 AM
  4. OEM Porsche Fuchs 6 X 15 Wheel with Michelin XWX Tire
    By 72targa in forum For Sale: 911 Parts
    Last Post: 01-15-2011, 06:03 PM
  5. FS : Five 4.5x15 fuchs with Michelin X spare
    By RS-GT in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 07:00 PM
