Results 1 to 2 of 2
Thread: Braided Fuel Line Size, 71T?
    I've got a stock 71T with Zenith carbs that currently has smooth rubber hose in the engine compartment. I'd like to replace it with the correct cloth braided hose since the smooth hose is obviously very old and wanted to know what size(s) I need. I can't seem to sort out exactly which size is correct as it seems people use both 7.0mm and 7.5mm ID hose in the engine compartment. Which is corrrect for a 71T?
    Also, is 9.0mm ID correct for the lines running from the tank to the pump?
    Lastly, which size hose is actually attached to the small brass fuel lines running along the side of carbs? It looks like stock diameter VW Bug fuel hose. Is this correct?
    Thanks in advance and sorry for the dumb question but I can't seem to sort it out from any of the manuals I've got.
    Stretch
    Although either works I prefer the 7.5mm hose, I think the larger size slips on the barbs just a little easier, besides why not use the larger size for more flow. 9.0 is correct for the suction side. I think the small fuel line you mention is 3mm, not sure, just measure the O.D. of the brass lines.
  1. PMO fuel pressure control unit - return fuel line?
    By lkadams in forum Technical Info
    Last Post: 05-27-2012, 05:58 PM
  2. braided fuel line
    By tull in forum Technical Info
    Last Post: 01-20-2011, 07:31 PM
  3. Early Steel Braided Cam Oil Line
    By Brad Davis in forum For Sale: 911 Parts
    Last Post: 10-13-2010, 07:43 PM
  4. Braided oil line hose, where to buy?
    By rcnagel in forum Technical Info
    Last Post: 01-14-2009, 06:00 PM
  5. Fuel Line
    By kissov356 in forum Technical Info
    Last Post: 06-26-2006, 12:45 PM
