Thread: Wevo or others require a 915 shift tower, correct ?
    I see that the Wevo shifter is available for model year 1972, but my car has a skinny shifter - not the big 915 shifter base. So, am I correct in thinking that if I want to retain the stock look, I'm S.O.L on that front ?
    Is there another all inclusive spring centered shifter alternative that works on skinny 72 915 shifters ?
    Greg.
    72 911T - 73 2002
    #1461
    Port Macquarie, Australia
    Wevo (which I have and love) requires a factory tower to complete. I understand the Rennshifter comes complete... other's may chime in on that.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    Shift linkage options
    Quote Originally Posted by Greg D. View Post
    Greg,
    I have the Rennshifter and it does come with its own shift base, but will in no way look like the stock shifter. Close, but no cigar, as they say, to a 915 shift assembly. More like a Mil Spec version of a 915 shifter, to my mind. Love the way it shifts.
    Some years ago, there was a spring & pin kit that improved the shift action of the early shifter.
    Here is a link: http://www.automotion.com/weltmeiste...r-porsche.html
    There is also a fellow on the Pelican site that sells a 915 modification kit, his name is Sherwood and it is called the Seine shifter. He has a lot of them in the field now, and I think it does what you may be looking for - mainly the spring loading of the action for more positive shifting.
    You might check into,that.
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
    The Robotek (no longer available I think) and the Seine system only work on the later 915 tower.
    I saw this on Pelican- http://forums.pelicanparts.com/porsc...shift-fix.html
    Read through the entire thread and make up your own mind of the benefits...the comments from Walt Fricke are worth noting. I don't know Walt personally, but from his posts he knows his stuff and has many years of hands on knowledge.
    Todd
    '71T 3.2 Spec 911 #806
    '69 BMW E9 Coupe
  1. Porsche Design Condo Tower, The Jetsonesque Tower
    By Unobtanium-inc in forum Other Porsche Passions
    Last Post: 01-18-2012, 11:11 AM
  2. Gearbox type info' require
    By MBEngineering in forum Technical Info
    Last Post: 09-07-2010, 07:54 AM
  3. Correct Shift Knob for SWB?
    By jaudette3 in forum Technical Info
    Last Post: 01-27-2010, 09:24 AM
  4. FS: WEVO shift knob
    Last Post: 09-09-2007, 08:46 PM
  5. Shift knob of '72 915 Correct?
    By Allen Henderson in forum General Info
    Last Post: 10-03-2006, 08:26 PM
