Results 1 to 2 of 2
Thread: H4 Upgrade Kit From Pelican
    Jul 2011
    Chicago Area
    Has anyone used the H4 Halogen Headlight upgrade kit that Pelican Parts sells for $54, if so is it a worthwhile upgrade?
    http://www.pelicanparts.com/catalog/..._pg1.htm#item1
    Mike Fitton # 2071
    2018 911S Carrera White
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    If you are ruinning NA spec lights and have old crappy sealed beams in there, you need to get the H4 upgrade. Add some relays and higher power bulbs and be amazed.
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
  1. Oil pump upgrade ?
    By stretch in forum Technical Info
    Last Post: 10-03-2013, 01:40 AM
  2. Got the upgrade bug
    By EA911 in forum General Info
    Last Post: 09-28-2010, 09:29 PM
  3. 2.0 to 2.2 upgrade
    By red67 in forum Technical Info
    Last Post: 03-06-2010, 07:25 PM
  4. H4 Upgrade
    By 356robo in forum Technical Info
    Last Post: 12-14-2008, 05:20 PM
  5. Battery upgrade or not?
    By Sacto S in forum Technical Info
    Last Post: 05-25-2006, 03:46 PM
