Results 1 to 8 of 8
Thread: 1967 911 insulation questions
    I am trying to locate the best match to original materials
    1. Horse hair type of product
    2. Felt roofing like material
    3. Padding
Size:  71.3 KBName:  DSCN3853.jpg
Size:  70.2 KBName:  DSCN3852.jpg
Size:  64.9 KBName:  DSCN3857.jpg
Size:  72.0 KBName:  DSCN3864.jpg
    Feb 2011
    Surrey, UK
    Well my first question would be 'why?', because they're all products that in no small part contributed to the rust pockets that plague these cars.
    To replace the horsehair I used the bonded felt shown in the photo from any upholsterers, and to replace the 'felt roofing' I used sticky backed acoustic sound pads again available from lots of outlets. These can be cut to shape and attach themselves well. I avoided using them anywhere water might 'pool' like the inner floors. Here I just placed the bonded felt under the carpets so they can be removed if necessary to let the metal dry out. I do not think you want anything stuck to the floor under the carpets. The floor is treated with POR 15 Rust encapsulator and POR 15 Chassis Black.
    I didn't replace any of the padding/wadding as all it does is provide a sponge for condensation, especially around the vent tubes at the base of the rear parcel shelf.
    Mick
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Guys, who sell this ?
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
    Atlanta, GA
    Here's one manufacturer.
    http://www.feltech.co.th/product1.php
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Is the felt better in any (functional) way than the closed-cell foam products?
    Atlanta, GA
    Quote Originally Posted by 37yrold911 View Post
    I don't know, but I read somewhere that closed cell foam does not hold water, which would be extremely important to me.
    Mark Erbesfield
    1957 356A #58648
    Apr 2011
    N.Calif., south of SF
    Interesting discussion. And the closed cell doesn't hold water but would keep it localized/trapped. Hmmm ... the felt would help moisture evaporate?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Feb 2011
    Surrey, UK
    Quote Originally Posted by Haasman View Post
    I thought long and hard about what to refit in the car shown in post 2. My experience with stripping several cars, and with my TR4A, is that unless you use some form of paint/coating (like Liquidskin) then any form of surface material, no matter how well you think it's stuck on, will have cavities and spaces underneath, and at some point these will get wet (condensation, window left open, spilled drink etc etc), and therefore it is vital that you can get the material out, and ideal if it can 'breathe' so at least it will eventually dry out.
    So I opted for this 'bonded felt' - stuck on with contact adhesive on the vertical panels, but just cut and loose under the floor carpet and the rear seats. The bonding gives it more durability, but it can still 'breathe'. I'm sure it will need replacing every few years especially on the drivers side, but it's cheap and easy to get.
    No right answer I'm sure, but this was my reasoning.
    Mick
    Note: I eventually removed the black sticky soundproofing from the rear seat bases shown in one photo for this reason.
  1. Replies: 0
    Last Post: 05-27-2013, 11:49 AM
  2. 1967 Insulation need help
    By vramani in forum For Sale: 911 Parts
    Last Post: 10-18-2012, 06:06 PM
  3. Source for insulation
    By merbesfield in forum General Info
    Last Post: 09-01-2012, 07:45 PM
  4. floor pan insulation
    By maxwedge528 in forum General Info
    Last Post: 07-11-2009, 04:55 AM
  5. 1967 911S- few questions
    By Alan.uk in forum Technical Info
    Last Post: 09-13-2007, 03:23 AM
