Another item off the checklist!
One of the challenges for original cars which lack adjustable rear springplates is achieving corner balance. On the one hand, early SWB cars need all the handling help they can get-- on the other, the lack of adjustable rear springplates makes the process of corner balancing time consuming, and pretty much impossible to dial in perfectly, due to the discrete nature of the adjustments.
What I mean by this is what everyone knows-- that the rear springplates ARE adjustable, but only through the vernier feature. There are 44 inner splines and 40 outer splines, so to make an adjustment down, for example, you go up one spline on the inner (360/44 = 8.18 degrees) and down one spline on the outer end of the bar (360/40 = 9.0 degrees). The net result is 9.0-8.18 or 0.82 degrees of adjustment down, and iterating both sides in this way will eventually allow you to dial in the correct ride height.
I was able to get it in the ballpark, but I don't have a set of scales, so other than measuring the fender height (not the "factory" way of measuring ride height, but the way everyone does it, because the "factory" way is impractical) I wasn't able to really dial it in.
For help I turned to Tom Florio, owner of Advanced Automotive of New Windsor, in New York's Hudson Valley. Tom has been in business for 24 years and works on many different cars, but is passionate about Porsches. He had six or seven inside and a few more around the shop. Also, in a very similar scene to what I saw at Peter Dawe's place back in August, he had a blown-up 3,6 that had vaporized a couple pistons hanging forlornly from a stand. Missed shift? No, it just let go.
Anyway, here's what Tom was able to achieve:
LF 520
RF 462
LR 728
RR 721
Left Weight 1238 (51.3%)
Right Weight 1183 (48.7%)
Front Weight 982 (40.4%)
Rear Weight 1449 (59.6%)
Cross Weight 1190 (49%)
Total Weight 2431 (with fuel fuel, spare tire and driver)
Not bad-- the front weight differs by 58 pounds, where 50 is negligible for a street car. The cross weight would ideally be 50% which means the car handles equally well on left and right turns, but again, this is a street setup without adjustable plates.
Now to alignment:
Front height 25.25"
Rear height 24.75"
This is approximate to the "Euro" ride height I wanted. I didn't want to go any lower, the car doesn't have a bumpsteer kit, nor do I want to start pushing the limits in that regard.
LF camber (0.6)
RF camber (0.7)
For a street car, big front camber isn't necessary and actually hurts braking performance. The factory spec'd Zero front camber in the revised settings for 1968, but a little negative will ensure that when the car rolls over (it has the stock 13mm pencil front bar and no rear bar) the outside wheel will be more orthogonal.
LF caster 6.9
RF caster 6.9
You want all the caster you can get. I am not currently using the steering damper. The factory did away with the steering damper in 1967 anyway. With these caster settings the car is nicely self-centering and at 80+ mph highway speeds tracked dead straight.
Front toe 0
An appropriate street setting. This car will not see AX.
LR camber (1.1)
RR camber (1.0)
This is right on the 1968 settings which were (1.1).
LR toe 0.08
RR toe 0.08
A small amount of rear toe, per standard. The factory said 0-10 arcminutes per wheeel, 0.08 degrees is 4.8 arcminutes per side (center of range) for 9.6 total. Perfect.
All-in it was a six hour job which I thought was extremely reasonable.
The new Hunter HawkEye alignment machine was particularly slick-- rather than attaching the targets with sharp clamps that go between the rim and the bead, Tom's new machine has targets that clamp to the tire directly-- then transmit light back to a tower on the machine that determines the precise alignment. Much more precise than I could do myself!
It was a great experience, if you're ever in the Hudson Valley and need some service for your 911, I highly recommend Tom, whose phone number is (845) 562-0346.
Now to get driving before the winter starts! Hope this helps those who come this way in the future.
