Results 1 to 9 of 9
Thread: Looking for 73 911S stock specs
    Apr 2011
    N.Calif., south of SF
    Does any body have the stock, original specs for sway bars for a '73 911S?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    May 2009
    West LA
    15mm front and rear.
    Registry Member #1583
    Apr 2011
    Thanks. I just measured my bars- front 19mm and rear 18mm. The front has an adjustable brackets, obviously not stock. The reason for all of this was a rattle and banging from the front end. It was diagnosed as bad shocks .... turned out to be worn out solid white plastic sway bar bushing. Sounded like the whole front suspension was loose and about to fall out.
    I am in search of at least new front sway bar bushings, (not hard plastic!) this is not a track car. My target is a great handling street car. The rear bar has rubber bushings.
    Hmmmmm buying used cars and then working on them is like an archeological forensic process ...... interesting what one finds.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Haasman View Post
    Haasman
    You may want to give Elephant Racing a call. They are near you. Ask for their recommendations. Your bar is very stiff and may not be compatable with rubber bushings. I'm afraid rubberbushings would be crushed and destroyed in short order with the bar you have now.
    Jim
    Apr 2011
    That's a good point and suggestion Jim. thanks. I'll give them a call.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Jun 2012
    London, Ontario, Canada
    In a 40 year old car that is to be driven on the street, I'd recommend going back to stock sway bars and rubber bushings. The less stress you put on the body the better. Rust, welds, metal fatigue. Why chance it ? Why stress the tub if you aren't going to drive like a maniac ?
    Early 911S Registry # 2395
    May 2005
    Oroville, CA
    I would consider the stock sways for street driving unless the roads are smooth where you plan do drive.
    If you want to try some stock sways, I can loan a pair..
    BTW now that it is home, how about a post in Show your ride?
    H
    Apr 2011
    Thanks for the offer Harvey. Also a good suggestion, I will post some pictures tomorrow.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Your existing bars with stock rubber bushings will work just fine, providing you like the added stiffness compared to the 15's. In your shoes I'd replace the front bushings and see if that's enough. Many people would barely notice any difference, others are more sensitive to larger bars.
    jhtaylor
    santa barbara
  1. FS: 1969 - 1971 911T, 911E, 911S Tech Specs Booklet
    By evokes in forum For Sale: 911 Parts
    Last Post: 12-10-2013, 05:53 PM
  2. 1967 911 / 911S / 912 / Carrera 6 Specs Brochure
    By Carl Bauer in forum For Sale: 911 Parts
    Last Post: 04-21-2009, 02:47 AM
  3. 1967 911S Alignment Specs
    By Greg Lund in forum Technical Info
    Last Post: 10-25-2008, 04:27 PM
  4. Stock Seats 73 911S
    By philip guiral in forum For Sale: 911 Parts
    Last Post: 08-05-2008, 04:04 PM
  5. Early 911S Rookie Needs Torque Specs
    By Bob Schaefer in forum Technical Info
    Last Post: 05-08-2004, 06:22 AM
