Thread: Wipers park right
    Junior Member
    Mar 2012
    Near Ft, Collins, Bellvue, CO
    Wipers park right
    My 1970 coupe wipers work fine but park to the right.
    Has the motor been changed or has the linkage flopped 180° ?
    Stormin
    That is a common (misguided if you ask me) modification to "get them out of the driver's visual field."
    What in fact ends up happening is when the wipers park on the off-side, a stream of water then flows up across the windshield. This is why the factory moved the parking location to the driver side in 1968.
    Reversal is simple. Wet the windshield, turn on the wipers until they are in front of driver, turn off ignition so they stay there. Then loosen the nut that holds the motor to the blades. Carefully, do not slice your fingers off, turn the ignition back on so the wiper motor parks. Then reconnect the blades.
    Once they are back where they belong, check to see that some PO did not bend the blades. Bending them is required when they are parked on the off-side. Get some photos here of correct original blades for a reference.
    And WELCOME to the forum!
    Welcome to the dark side Norm. I saw that you sold the GT coupe. Do you still have a 356? I still have the ivory 58 speedster but drive the 900's much more. Welcome! SS#2
    Junior Member
    Mar 2012
    Hi Steve,
    I still have a 356 a C coupe Outlaw. In Porsche Tangerine and the 70 911T also in tangerine.
    One must always have at least one 356 !
    Good to hear from you and by the way did you know Kurt's shop burned during our big fire?
    He is rebuilding and has the walls up now and waiting for thr trusses.
    Norm
    Junior Member
    Mar 2012
    304065 Thanks,
    I suspected that was the case and can change them over soon, looks better and no danger of being in my vision as my head just clears the sunroof as it is.
    Stormin
    9110121936
  1. FS: NOS SWF rear wipers
    By uai in forum For Sale: 911 Parts
    Last Post: 03-09-2013, 01:17 PM
  2. 71 72 wipers problem help
    By gwilliams in forum Technical Info
    Last Post: 02-15-2009, 09:06 AM
  3. NOS 65 to 67 Wipers, OEM
    By Soterik in forum For Sale: 911 Parts
    Last Post: 05-21-2008, 05:11 AM
  4. FS Silblade wipers
    By adam912 in forum For Sale: 911 Parts
    Last Post: 02-18-2007, 12:05 PM
  5. Chrome wipers
    By joetiii in forum General Info
    Last Post: 09-22-2006, 11:39 AM
