Thread: Weber jetting: Over heat problem
    Question Weber jetting: Over heat problem
    Hi all,
    I've had a big over heat problem which damaged my motyor last july.
    It is a 2,4l S which is up setting in 2,7l.
    I put 2 weber 40 IDA3C/C1 which setting is:
    Venturi: 30
    Main jet: 125
    Air correction: 180
    E-tube: F26
    It seemed not to be so poor, but should this setting be my over heat problem ?
    Rgds
    Freddy
    Hi Freddy,
    Without question, your jetting package is FAR off for a 2.7RS spec engine and can make it run hot due to excessive leanness.
    With S/RS cams, you really need F3 emulsion tubes so you should locate a set if you can. F26's are too rich and intended for engines with 906/RSR cams.
    30mm venturies are too small for a 2.7, even for a 2.4S engine.
    Unless you live above 5000 ft elevation, I'd be using 34mm venturies with 150-155 mains and your current 180 A/C jets. 36mm ones give better top end power, but a little softer below 4K RPM.
    55 idles should be perfect.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Thanks a lot steve for your tip.
    SO i need to change venturi, e-tube and main jets.
    Do you know where i can find this kind of parts for my webers.
    Rgds
    Freddy
    Hi Freddy,
    I can certainly provide the main venturies & jets, however I don't have any F3 e-tubes and they are NLA. The only source would be to find a used set of them.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    I sent a email to you steve.
    There is a mistake, i need 150 and not 145 main jet.
    Rgds
    Freddy
  1. Correct Weber jetting for a 2.9?
    By s2guy in forum Technical Info
    Last Post: 01-21-2010, 08:48 AM
  2. Nedd Help With Weber Jetting
    By gruen911 in forum Technical Info
    Last Post: 09-23-2009, 04:59 AM
  3. Weber Jetting
    By pacarguy in forum Technical Info
    Last Post: 06-28-2008, 10:27 AM
  4. Weber jetting on a 2.2 E
    By RPMClassic in forum Technical Info
    Last Post: 05-06-2008, 11:44 AM
  5. Weber 40 IDA jetting
    By zaza in forum Technical Info
    Last Post: 03-08-2005, 09:51 AM
