Results 1 to 10 of 14
Thread: whats wrong with this picture?
    got a pickle of a problem..........
    Richard aka le Zookeeper
    early reg #1128
    Aug 2009
    SF Bay Area
    Richard
    You just lost the threaded pin that secures the coupler to the shift shaft on your trans. Now is a good time to replace the coupler bushings while you are putting it back together. Check to see that the threads in the coupler have not been stripped. I can send you a rebuilt coupler with the retaining pin, if you like.
    Jim
    www.easypor.com
    didnt lose the pin...something else is wrong??? who can spot it??
    early reg #1128
    Jan 2007
    North of the GG Bridge
    Inner and outer rubber boot? Isn't there a detent in the shaft for the tapered safety wire bolt?
    Aug 2011
    Australia
    You dont seem to have the countersunk locating hole in the selecter shaft?
    S Registry#2021
    Richard, there's no hole in the shift shaft for the conical screw! How in the world did that happen? Well, it's easy enough to drill one.
    The rust on the shaft will bugger the seal. If you can, polish the whole shaft before final assembly. Even some emery paper looped over the shaft from below and run back and forth would probably help.
    Dec 2003
    West Los Angeles
    I've seen the "detent" hole for the locating screw pin enlarged, but never absent. Fairly sure your transmission is not upside down, so... ?
    techweenie.com
    Indeed the hockey stick is upside down...!!!! the hole is at the bottom??? how is this possible?? can it work that way? I havent tried yet, this car has been sitting this way for a while. I thought for a sec that the trans was maybe upside down
    I was getting ready to drop this engine and trans when I noticed this. Weird now I wonder if it can still shift this way, I think I'll try and see before I remove it...just boggles the mind what one finds.
    Did 356 trans have a detente hole from the beginning or was there another way they were secured??
    early reg #1128
    Mar 2006
    Louisville KY
    Is it a 356? Just cant think of anyway the shift rod could turn 180 degrees in a 901/911 or a 915.
    Tony Proasi
    52 split window coupe
    Jan 2007
    Phoenix, AZ
    I had an upside down shaft on a 901 before. No big deal, just flip the coupler and test your dexterity installing the screw upside down.
  1. Am I wrong for liking this?
    By car-reras in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 05-05-2012, 06:22 AM
  2. what's wrong with this picture?
    By Homemade 911 in forum Off Topic
    Last Post: 02-10-2009, 01:52 PM
  3. what's wrong here?
    By 67Porsche911S in forum Technical Info
    Last Post: 04-05-2008, 07:58 AM
  4. Anyone ever have a COA with the wrong color?
    By Kaleid in forum General Info
    Last Post: 03-04-2008, 12:51 PM
