Results 1 to 10 of 10
Thread: question re heater duct through chassis - solution needed
    Sep 2008
    Auckland , New Zealand
    hi guys ,
    well i have a slight issue due to a change of plans for my 72 that i was doing a ST build on. due to one thing and another plus now having 2 r-gruppe style cars i decided to kill the ST plan and head the car straight back to original spec. (911T with S package in Albert blue ) BUT when i did all the body work and as i was running race car spec i removed the heater tubes out of the inner sills . Now that she is heading back i see three opitions unless someone has a bright idea.
    - run no heat
    - run heat into the sills and see how that transfers
    - pull the sills off and reinstall
    or ???????????????
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    John, I'm sure you've considered a Webasto??? Easier than undoing rocker sills!!
    Sep 2008
    could do , i mean i don't need heat as we live in a temprit climate , but for correctness and look i did think just run the heat as normal and hopefully the sills don't get hot IF someone uses it and the noise is not transferred .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    I really don't have much faith in that working
    Nov 2006
    S. F. Bay Area
    Me neither. The piping that runs inside the sills also contains silencers which keeps engine noise at bay. Since you are going for originality here, I don't see a way around it. JMHO. Brian
    Brian
    S Reg #1032
    Sep 2008
    Well parts are cheap so just labour needed .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Port Macquarie, Australia
    Webasto won't fit in a RHD... or is it a left hooker?
    John, you can access the tubes "from the other side" inside the cabin... You can see the rivet heads that attach the tube clamps with the carpet pulled away. If you go in this way, you can just cut a 'hatch' to install the new tubes and then stitch it closed again - the welds won't be visible under the carpet.
    I don't think "tubeless" will be particularly effective.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Sep 2008
    was thinking that , i would have to get the muffler for the inside to see size of cut etc... will talk with the panel guy.
    car is lhd german delivered
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Hole doesn't have to be exact. The tubes just push on... do one end, then flex the tube and push on the other end, just wear gloves so you don't cut up your hands in the process
    John Forcier
    EarlyS #1987
    Restoration Saga
    What did you do finally ?
  1. FS: Right Side 73 Engine Heater Duct
    Last Post: 12-26-2013, 01:58 PM
  2. WTB: right side plastic heater duct (off fan)
    By Kaleid in forum For Sale: 911 Parts
    Last Post: 03-10-2013, 05:44 AM
  3. Heater duct cover plates
    By advtracing in forum For Sale: 911 Parts
    Last Post: 08-05-2012, 05:37 AM
  4. Engine bay heater duct covers - useful ?
    By advtracing in forum General Info
    Last Post: 07-09-2012, 05:55 PM
  5. 911 R front duct pattern needed pls
    By TRE Cup in forum Technical Info
    Last Post: 05-14-2007, 07:34 AM
