Thread: 901/02 gearbox rebuild, advise please
    Jul 2012
    Kent, UK
    Am looking to rebuild original transmission s/n 4280506.
    Need to replace main shaft, first gear set, and bearings. Where can I source these parts, bearing, new preferred, shaft and first gear set will need to be used I suspect.
    Are there sensible upgrades that should be considered for the gearbox at this point ?
    Pictures in my restoration thread.
    many thanks rich
    Rich
    68 911S
    mbr. 2393
    Aug 2007
    Phila Pa. area
    mainshaft
    i have mainshaft and gear, pictures tomorrow.
    Mike
    Jul 2012
    Kent, UK
    Thanks Mike,
    do you have the full 1st gear set ?
    regards Rich
    Rich
    68 911S
    mbr. 2393
    Jul 2012
    Kent, UK
    see the wear on rest of set..
    Name:  1st gear set1.jpg
    Name:  1st gear set.jpg
    Rich
    68 911S
    mbr. 2393
    Aug 2007
    Phila Pa. area
    gearbox
    Rich
    You asked for a mainshaft. I thought I had one, but they turned out to be three, 356 mainshafts. I may be able to get one from a friend. The gear that is cut into the shaft, unless you have a 904 mainshaft, is second gear and you need the matching second gear. You said you need a first gear, and show the small gear of a first gear set and say its damaged. I don't see any damage in the picture, You also show another gear and say its damaged? Its the reverse idler gear, and I don't see any damage on it either. I have attached pictures of my first gear set, and reverse idler. I am sorry about the mainshaft I thought for sure I had several. I will ask around, but wanted to get something out to you as soon as possible. The gear sets, as well as the mainshaft come in matched pairs in case you were not aware.
    mike curnow
    Mike
  1. FS Dr Evils 911 / 912 / 914 gearbox rebuild dvd's new
    By advtracing in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-17-2011, 12:44 PM
  2. Any interest in a 901,915, or 930 gearbox rebuild kit?
    By Erik@Carquip in forum For Sale: 911 Parts
    Last Post: 12-14-2010, 03:11 PM
  3. strut advise
    By james in forum Technical Info
    Last Post: 03-15-2007, 12:03 PM
  4. Advise
    By platas in forum For Sale: 911 Parts
    Last Post: 07-09-2005, 09:37 AM
  5. please advise me!
    By d_o_n_k in forum General Info
    Last Post: 02-13-2004, 11:18 AM
