Thread: '65 Shifter Linkage - Need an NLA Part
    Mar 2012
    The gear shift bracket - 901-424-015-02 holds the shift lever to the floor. It has a pin that is used to locate the shift lever ball (the ball has a slot in it) and prevent the lever from spinning around.
    My pin has sheared off. Standard supply places show 901-424-015-02 as NLA. Any ideas where to go to try used or anybody have a spare in good shape. Anybody ever reweld the pin? Thanks in advance.
    EDIT: PS - never mind - they are available used no problem. I thought this was going to be a lot harder to find.
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    Hi Bruce, that part number is for the whole base....which I would expect to be NLA. I do not see a parts breakdown for the pin. It is part of the shifter. You have 2 solutions; get a hardened pin ground to the size you need from a local grinder or get another shifter.
    Edit: didn't see your edit!
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Aug 2009
    SF Bay Area
    I know of a place in Emeryville that can help you with a shifter base.
    Jim
  1. WTB: shifter part
    By Bob Alfonso in forum For Sale: 911 Parts
    Last Post: 08-18-2013, 12:33 PM
  2. FS: Shifter linkage cover
    By denson in forum For Sale: 911 Parts
    Last Post: 02-01-2013, 11:48 AM
  3. Replies: 8
    Last Post: 11-14-2012, 02:54 PM
  4. WTB rear wiper linkage part
    By CarmelSkip in forum For Sale: 911 Parts
    Last Post: 03-03-2009, 03:10 PM
  5. Replies: 4
    Last Post: 07-23-2005, 06:43 AM
