Results 1 to 8 of 8
Thread: Mahle 911E P&C's
    Jun 2003
    Bend, Oregon
    Mahle 911E P&C's
    A friend of mine has a set of Mahle 911E Pistons & Cylinders that are almost new - they were in a car for about 3,000 miles and removed. The set also includes new rings. He's asked me to sell them for him and I can't for the life of me figure out what they might be worth. My early research indicates probably less than he thinks because it seems that most folks opt for S P&C's when they do a rebuild.
    Can someone tell me what I should ask for these? Maybe just list them on eBay?
    Thanks for your help.
    Cheers,
    JohnA
    John my best guess is around $400, even though it was 'only' 3,000 miles they're really not new anymore. (of course I could be WAY wrong )
    Jun 2003
    Bend, Oregon
    Thanks, Ed. I doubt you're way wrong.
    Cheers,
    JohnA
    2.2 E ? if so LMK
    Jeff H.
    72 911
    914-6 GT
    Jun 2003
    Bend, Oregon
    I've always thought that the 2.2 and 2.4 liter E's used the same P&C's as the bore was the same. My understanding is that the increased displacement was achieved through a longer stroke. If that's correct, then this set of E P&C's should work with either a 2.2 or 2.4 configuration.
    Jul 2006
    Washington D.C
    Yes. I believe they both are 84mm, biral bores.
    Andy (VA).
    Dec 2010
    Tulsa
    I believe the wristpin placements are different; that's why the 2.2 S set is an easy upgrade for 2.4 motors. You can gain about half a point of compression.
    All 2.2 pistons have higher domes than their 2.4 counterparts.
    Putting a 2.2 piston in front of a 2.4 crank will yield a nice bump in compression and, therefore, performance. A great upgrade for the 2.4 rebuild on a budget.
    -Marco
    TLG Auto: Website
  1. Replies: 2
    Last Post: 03-24-2013, 10:52 AM
  2. Replies: 0
    Last Post: 03-18-2013, 09:17 AM
  3. NOS NLA 73 1/2 2.4 Mahle P&C set
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 08-29-2010, 04:40 PM
  4. FS: Set of Used Mahle 84V51 2.2 911E Pistons
    By M491 in forum For Sale: 911 Parts
    Last Post: 09-26-2008, 03:18 AM
