Hello everybody. Mine name is Glen. I'm the friend of GregD who recently purchased a 68 911 and have been having some issues that he has been asking questions on. As I work through them I run into more questions. But my buddy Greg came up with some lame excuse that it would be easier if I joined the forum and asked the questions directly (personally I just think he's lazy.
Ok, based on previous info provided regarding the temp sender location. I have taken a old VDO sender from a 912 engine I have (been told its the same since I have 912 style gauges) and replaced the sender (A Beru) that was working the gauge. I went from showing a car that was nearly over heating after 20 mintues to a car running at hat I consider normal range after 25 miles. Now again with info provided. It was confirmed that the sender on right is the correct location not the operational one on the left. The VDO 912 sender in that possition does not seem to be working. So I moved the 912 sender from the left hand hole and installed in correct location on the right. I then started tracking wires.
This is what I found / did. Both senders are connected to green with black wires (believed to be correct). I tracked the right hand sender wire to the back of the engine compartment where it connects with push connector to a green with red wire that comes up between the body and the engine from the starter area (it IS s a wire that comed out of the factory harness). I then tracked that green with red wire to the gauge area where it has been zip tied and is not connected. So this right hand sender has been a dummy. I then took the left hand sender wire and wrapped it around the rear of the engine compartment and attached it to the green with black wire that went to the right hand sender. The wires are perfect length, and this connection looks like it was originally this way. I then took the original left hand Beru sender and put it back in the left hand hole just to fill the hole in the timing cover. This was done at 1am last night. All seems to work but I have not had a chance to test drive to check temps.
Now I Currently have three quesitons regarding this particular issue.
#1 What is the green and red wire for?. It comes out of the harness near the starter and and ends at the gauges.
#2 Based on info, it sounds like the timing cover is off of an SC (as that is the only one with a hole where this left hand sender went). However per the one book GregD loaned me (more books are coming rest assured), it says that the covers are universal from 69 thru 83. But mine is a matching number 68 with a build date of May 68. Would an SC cover still fit my car? If not, then what do I have here?
#3 Why would somebody do this? It not like somebody amaturishly ran a wire and re-routed. They used the correct color wires where visible etc... I get the feeling this was done professionally. I don't get the point! Any ideas?
Thank
Glen
