Thread: Turn signal and windshield wiper questions.
    Aug 2010
    Colorado
    I have 2 questions about my 1967.
    1. After my windshield wipers have run for 5 or 10 minutes they don't want to turn off. Is the issue in the motor or the stalk? I'm guessing the motor is heating up and something changes ot cause the issue.
    2. My turn signal stalk doesn't want to hold a right hand signal most of the time and when it does it needs to be turned off manually. Do I need new springs? How do I fix it?
    Your help will be much appreciated, Chris Pomares
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Chris, I think the wiper motor needs to come out to be checked, after making sure that it's wired correctly, it does sound strange.
    With your indicator problem, did it work properly before? It could be either the springs, or it could be the cancel ring, if you or someone else has worked on your car?
    Tony
    Aug 2010
    Colorado
    Tony,
    Both the wiper and turn signal stalk have been like that since I bought the car 2 1/2 years ago. I was focused more on the POLO engine conversion, transmission, suspension, interior and other details in the past. Now I'm down to these kind of details. So if anyome has taken the wiper motor apart or fixed either of the steering collum stalks, I'm all ears.
    Chris
    Aug 2007
    Phila Pa. area
    switches
    Sounds like your window wiper switch has burnt points and are sticking. The same with the turn signal.
    Mike
  1. FS: turn signal and wiper switches from a '72
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 06-20-2014, 02:44 PM
  2. FS: Early Turn Signal / Wiper Levers
    By jhora in forum For Sale: 911 Parts
    Last Post: 01-15-2013, 07:13 PM
  3. SWB 911/912 Turn Signal & Wiper Switches & Housing 65-67
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-08-2012, 05:37 PM
  4. FS: SWB 911/912 Turn Signal & Wiper Switches & Housing 65-67
    By rennmark71 in forum For Sale: 911 Parts
    Last Post: 10-07-2011, 03:50 PM
  5. 911 Fuch Wheel,Turn Signal Wiper Switch & more
    By 911devotion in forum For Sale: 911 Parts
    Last Post: 12-21-2009, 06:55 PM
