Results 1 to 7 of 7
Thread: Dash switch knobs Restoration advice.
    Ok, so this is what I have to start with.
    I found new cups for replacement(with no holes for light) which I think they can be drill, but thats about all that its out there. I don't know how the plastic light tube work? If the ones in my picture are broken or 1 OK and one broken? The defroster and the fog switch seam to come with light but I haven't found much info or exploded views on this to bring this switches to optimal restauration. Any advice will be greatly appreciated.
    Member-1969 Sand 911S
    Aug 2010
    Utah
    Carefully clean and keep the lenses, buy new rubber from Eric, $12.00 each.
    Feb 2010
    San Francisco, CA
    Rubber parts can be found at Eric L's shop here:
    http://www.autoforeignservices.com/index.html
    E911SR & RGRUPPE
    '73 S Coupe #306
    Ok the rubber part it's under control, but what about the niylon tube? How does it work? I can't find replacement.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    It just carries the light from the globe to the end of the switch.
    It's just acrylic rod, easily found. Just cut it to the required lenght.
    Nail polish works well for the end of the tube. Just raid the wife's.
    Tony
    Great! Thank you.
    Dec 2004
    SE Michigan
    Regarding light rods, please let us know where you buy replacements. IIRC, they are 4mm diameter, which is a size that does not appear to be readily available in the US. There's some overseas shops that carry it, but it would be nice to find a source in the states.
    Bill G.
    EarlyS #718 | RGruppe #437
  1. Restoration advice
    By tycamcody in forum General Info
    Last Post: 01-01-2015, 10:19 AM
  2. Replies: 0
    Last Post: 08-13-2011, 01:19 PM
  3. Where to buy dash knobs?
    By pactronics in forum General Info
    Last Post: 06-05-2011, 03:13 AM
  4. Dash switch advice rqd
    By Fleetwoodcat in forum General Info
    Last Post: 05-10-2007, 02:18 PM
  5. WTB: Set of Euro Dash Knobs
    By RTincher in forum For Sale: 911 Parts
    Last Post: 03-23-2007, 06:10 PM
