Thread: Powder Coat a Trombone Cooler?
    Feb 2010
    San Francisco, CA
    I'm going to be restoring a '73 trombone cooler and was wondering if there was any reason not to powder coat it? Given their inherent lack of cooling efficiency I was thinking that the powder coating material might not allow heat to escape as well as paint?
    Any truth to this?
    Thanks in advance.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    There are two types of different powder coating materials, thermoplastic(nylon,polyester) and thermoset(epoxy). Thermoplastics will remelt and circulation at less than 500 degrees F and will also be suffering from liquids. Thermosetting coverings crosslink significance that they are unaffected by most solvents as well as being heat stable after the first treating procedure. I think that if you are coating cast parts than you shouldn't have any issues with cranking but aluminum may expand and contract too much during heat cycles and cause bursting in a thermoset product.
    Sep 2006
    Eagle, Idaho
    Quote Originally Posted by kentf14 View Post
    Kent
    You open by stating your intent to restore your trombone cooler, and then in the same sentence promptly segue into asking if there's any reason not to powdercoat it.
    Doesn't the term "to restore" imply "to return an item to its original state" ? Were trombone coolers ever powder-coated from the factory? No, of course they weren't.
    They were quite ineffective at best with the standard, thin factory coat of black paint and being mounted behind the passenger-side battery box, where there is very limited airflow, so why on Earth would you want to further reduce the efficiency of this marginal item by powder-coating it to encapsulate more of the heat?
    ...........and that holds true for the external oil lines as well. They probably contribute more to the oil's temperature drop than trombone coolers ever can and will, by virtue of being more exposed to ambient temperature air passing over them, as opposed to hiding behind a battery box where the trombone lives. A thin coat of black paint for appearance's sake and leave 'em be
    Respectfully
    JZG
    Feb 2010
    San Francisco, CA
    Thanks for the info John. My use of "restore" versus your interpretation of my usage differ in semantics only. I was looking for a way to refresh the cooler while providing additional protection over the factory paint. Knowing myself the limitations of a trombone cooler I was hoping that someone could comment on whether powder coating would significantly decrease efficiency.
    Sounds like you are saying that powder coating is not recommended.
    Thanks for the advice. I will use paint.
    -Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Jun 2012
    London, Ontario, Canada
    If the point is to best preserve the cooler, then powdercoat is tougher than paint, even if it is not "correct".
    While the thermal conductivity of powdercoating materials is about 100 times worse than copper, the powdercoating is actually about 100 times better than air and that sets the ultimate heat dissipation. So do what you want. It won't change the operating properties of the trombone in a dead air space.
    Early 911S Registry # 2395
  1. FS: 1971-1972 Rear Trailing arms. Refinished in powder coat - $500
    By bdstone914 in forum For Sale: 911 Parts
    Last Post: 12-15-2013, 02:41 PM
  2. FS: Engine Tin & Muffler Mount Fresh From Powder Coat
    By 76911S in forum For Sale: 911 Parts
    Last Post: 12-22-2012, 11:30 AM
  3. Replies: 5
    Last Post: 10-01-2012, 01:11 PM
  4. WTB: Trombone Oil Cooler
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 02-08-2012, 11:49 AM
  5. Chrome to Powder Coat
    By Brad Davis in forum Technical Info
    Last Post: 01-17-2009, 04:20 PM
