1969 Porsche 911T VIN 119122765, engine # type 911/52, gearbox number 9153011020P
Currently set up for track days, vintage or club racing. The car has been raced in SCCA and vintage events locally for over 20 years. Tub is very clean and rust free. All the typical rust problem areas such as the front suspension pan, floor pan, rear sway bar mount area, etc. show no signs of rust. Both the front battery boxes have been removed, the left side has a sheetmetal patch over the area, the right front side has a very nicely made oil cooler with custom fabricated aluminum ducting. With so much of the factory components still in place, it wouldn’t be out of the question to put it back on the street. The factory wiring harness is still installed and has not been cut up. Any connectors or wires not being used have been tied back. The turn signals, wipers, lights, dash gauges, brake lights all still operate. The fuel cell has a level sender built in so it even reads on the stock dash gauge. The factory headliner is in great shape for its age with only minor fading/yellowing. The upholstered door panels, rear interior panels and rear window tray panel are in great condition. The face of the dash and the dash pad itself are good except where the speaker grill is. Here are a few details:
- Genuine Porsche 15x6” wheels
- 915 gearbox
- Fiberglass hood, front bumper, rear bumper and engine lid with duck tail spoiler
- Stock steel rear engine lid included, painted to match car with numbers and emblems in place
- 10k rpm tach
- New Willans harness, exp. 2017
- Custom aluminum front oil cooler ducting
- Custom aluminum fuel cell container
- 2.2 liter engine, freshly built, break in and one track day of time only. 40mm Webers, mag case
- Halon fire system
- Adjustable front and rear sway bars
- 6 points bolt in roll cage
- Matching driver’s and passenger race seats
- Momo Champion steering wheel
- Welded in front strut tower brace with camber adjustment rods incorporated
- Factory wiring harness
- Plastic headlight lenses molded to replicated to look like factory lenses
- Factory front and rear turn signal lenses
- Exterior paint in good condition, shiny and smooth, showing signs of light use, no major rock chips, dents or rust.
- Plastic rear window with factory seal and lock strip in tact, plastic side quarter window with molded in louvers using the factory frames, seals and latches.
- Glass windshield in good condition with a factory seal and lock strip, some very minor chips, no cracks or starring
- Doors still have stock glass with the roll up window regulators that operate smoothly
- Rechargeable AMB transponder
- 2 binders full of on track data, set-up info and wiring modifications diagrams.
- Stock front and rear brakes in good working condition with a front to rear bias adjusting valve under the dash
- Gearbox oil cooling system including an external pump and cooler
$39,000, delivery possible to various west coast vintage events
60+ Additional photos can be found here:
http://www.flickr.com/photos/racecra...7631801497720/
This is posted under a friend's log-in account so please contact me directly not through the forum. jimfroula@yahoo.com 425-766-6800
