Results 1 to 10 of 10
Thread: 1965-1973 gas tank support
    Dec 2011
    Guelph, Canada
    We now have the correct, not copies of superceded parts, 1965-1968 and 1969-1973 gas tank supports. These parts were stamped out this week and are now in stock for shipping. A number of you were waiting for these. Phone in your order or place the order on line.
    65-68 Support with the battery tray.
    69-73 with hole for battery strap.(battery strap not included)
    Mike deJonge
    Restoration Design Inc
    519 836 3555
    www.restoration-design.com
    Mike:
    Please post your pricing.
    Dec 2011
    Guelph, Canada
    #P204A 1965-1968 gas tank support each $115.00
    #P204B 1968-1973 gas tank support each $105.00
    shipping extra
    can be ordered by phoning in or online thru the website, www.restoration-design.com
    Thanks much...
    Thank you, now I won't need to spend the time cutting off the protrusion and welding back up!
    Oct 2005
    Minneapolis, MN
    Thanks Mike...this is very nice!
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Senior Member 911scfanatic's Avatar
    SE Michigan
    To my eye, there appears to be a wrinkle in the stamping, which if true will need to be reworked. I have had this problem with other stampings I have purchased from various sources.
    Mike, can you confirm or deny the presence of wrinkles in the pictured stamping (near the battery support surface).
    Bill G.
    1968 911 Ossi Blue coupe...restoration complete!
    EarlyS #718 | RGruppe #437
    Hi, just for file they are not correct for all 73 cars. The tank support changed to the later style during the 73 production year.
    HTH
    Alan
    Aug 2007
    Phila Pa. area
    fromt pan
    Except for the hole over by the battery box and the separate battery framework, which is welded separately, both pictures seem to be the same? Am I missing something?
    Mike
    I was very excited to hear about this piece. Finally someone is stamping the correct 69-72 panel! Got it this week - somewhat disappointed.
    I had previously bought a repro from another vender and was unhappy with the fit. I then bought an original NOS green primer (with 901 part #) piece from a fellow S Reg member and found that it fit perfectly. Unfortunately, it was a factory superseded part and had the 73- bump out on the driver side. That wont work, so I thought that this new repro would be my salvation.
    First thing I noticed when I took it from the box was the wrinkles in the top from the stamping process. Then I see that the hole and the weld nut for the charcoal canister strap was missing as is the little tab that holds the cardboard fuse box cover in place. Irritating, but I can deal with that.
    Laying it into position, I find that the hole for the battery strap is about 1/2" out of position and most of the flanges don't lay tight to the existing metal. Keep in mind, I have a vintage NOS panel that lays in place perfectly, so its not my car to blame.
    Yes, it can be made to work fairly easily, but Im going to spend another $100+ with my metal guy making it right.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  1. '73 RS front tank support.
    By Flat Six, inc. in forum General Info
    Last Post: 04-16-2014, 01:12 PM
  2. FS: NOS 69-73 Porsche gas tank support
    By Shaun 69 E in forum For Sale: 911 Parts
    Last Post: 12-20-2009, 09:51 AM
  3. FS: Fuel Tank Support
    By WCB4 in forum For Sale: 911 Parts
    Last Post: 05-05-2008, 11:47 AM
  4. Gas tank lateral support
    Last Post: 06-19-2007, 04:09 AM
