Thread: Want to replace L & R window scrapers .... can someone tell me how to
    Apr 2011
    N.Calif., south of SF
    ... remove the chrome molding piece that holds the rubber on the top of the door next to the glass?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    May 2005
    Oroville, CA
    The trim piece is not bolted. It comes off with careful prying. I start at the end and work forward. Sometimes the clips are crusty and need some convincing. Careful not to bend or chip the paint...
    H
    Apr 2011
    Thanks Harvey!
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Apr 2011
    So the easy part is removing the chrome trim and the old rubber "scrapers" ..... the chrome piece and what a nightmare sliding the new rubber scrapers on.
    I tried: WD40, silicone spray, silicone lube, plumbers paste, TriFlow, water etc ....
    ....but what really worked ..... Dawn Dishwashing detergent. Yep, I know weird, but it works great. Not diluted, BTW. It is incredibly messy and slippery, so much so that a rag is needed in order to get a goo grip on the rubber window scraper insert. Be sure to get the Dawn all over the channel in the chrome piece and especially in both grooves and bottom of the new rubber piece. A helper/second set of hands really helpful.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Feb 2010
    San Francisco, CA
    And just wait for the rain. You windows will suds up and clean themselves
    The new scrapers are a PITA. I ended up using a one of those plastic window gasket tools to shove one side into the channel. It took a lot of small incremental "shoves".
    Good thing these don't need replacing all that often.
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. Refurbishing horns, or replace?
    By reedminor in forum Australia
    Last Post: 10-15-2013, 09:01 PM
  2. Radio Speaker Replace
    By John Straub in forum Technical Info
    Last Post: 05-25-2012, 08:31 AM
  3. Replace this tank?
    By clesch in forum Technical Info
    Last Post: 03-13-2012, 02:28 PM
  4. Looking to replace batteries with dry cells
    By Perry911 in forum Technical Info
    Last Post: 06-03-2008, 02:02 PM
  5. Rebuild or replace electric window lift
    Last Post: 01-12-2007, 01:39 PM
Tags for this Thread
