Thread: Electrical terminals
    Can anyone recommend a source for good quality crimp-on electrical terminals -- male and female - similar to OE size and configuration where one crimp is made on the insulator and the other on the wire (I have the special crimp tool). Local Napa store has junk and I'm not sure if sizes are metric or universal. My original supply obtained from an automotive factory is almost gone.
    Thanks in advance
    John Schiavone
    Connecticut
    John,
    OK, you say you already have a correct F-type crimper, that's good. It should look like the one in this thread, a Knipex.
    http://www.early911sregistry.org/for...ghlight=f-type
    This stuff is a commodity, best place to buy it is from one of the huge supply houses. I use Digikey.
    For example, A100798CT-ND CONN RCPT FASTON STRGHT 16-12AWG
    You can play with their filter to change the wire gauge, length of the insulation crimp, size of the tab, whether you want a male tab also, etc.
    Good luck!
    Oct 2008
    Burford, ON, Canada
    I have some reels of that type (1/4")
    Thanks #304065, that's exactly what I'm looking for! Didn't know style and crimper are referred to as f-type, the only way to go.
    Thanks again,
    304574
    John Schiavone
    Connecticut
    Oct 2005
    Minneapolis, MN
    Wurth online...
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
  1. An electrical why
    By yale in forum Technical Info
    Last Post: 04-03-2012, 02:30 PM
  2. Electrical Help Please
    By 67SWT in forum Technical Info
    Last Post: 05-04-2010, 05:26 AM
  3. Electrical short 73T, help please....
    By kilodawg in forum Technical Info
    Last Post: 12-28-2007, 07:58 AM
  4. Electrical
    By Lee in forum Technical Info
    Last Post: 09-28-2005, 08:30 AM
