Thread: SWB undercoating and engine compartment paint recommendations?
    Sorry if this has been asked before... I attached some pictures of my 68. I want to get the whole underside and engine compartment looking good. Having it original to Porsches factory coating doesn't matter, it's going to be a hot rod. I just want everything to be clean and black. I would prefer to brush rather than spray. I know POR-15 can be brushed. Should something go on top of that as well? Use the same stuff in the engine bay? Torsion bar tubes? Trailing arms? etc. I also read good things about some Wurth products but those are spray only? Any help would be appreciated.
    search for "schutz"
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    I used Wurth with great success. Here is a rough picture (phone pic sorry), I'll take some better pictures and post them. The key is multiple thin coats. Takes forever to mask everything off, but it's worth the effort.
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    Can I clean up the floor pan (without stripping the undercoating off) and go over it with POR-15 or something similar?
    Aug 2011
    New York
    POR15 can only work on bare steel, it is not meant to be applied over another coaiting. They recommend a top coating over it for UV protection.
  1. '69E Paint and undercoating questions
    By rdelmendo in forum Technical Info
    Last Post: 10-10-2013, 06:52 AM
  2. A few questions regarding paint and undercoating
    By emnemn in forum General Info
    Last Post: 03-09-2011, 05:21 PM
  3. Engine compartment paint and color code
    By ferry58 in forum Technical Info
    Last Post: 10-12-2009, 12:12 PM
  4. How Glossy Should Engine Compartment Paint Be (Black)?
    By Scott Clarke in forum General Info
    Last Post: 04-06-2007, 02:34 PM
  5. Replies: 12
    Last Post: 11-09-2005, 04:11 PM
