Thread: whats gas to use?
    whats gas to use?
    on my 72 T?
    thanks
    87 octane (good old regular) should be just fine. Where are you located?
    Peter Kane
    '72 911S Targa
    The stock compression ratio should've been 7.5:1. Higher octane fuel will provide no benefit unless there is build-up in the compression chamber (such as on the top of the piston) that is rasing the compression and causing knocking. What have you experienced so far?
    Peter Kane
    '72 911S Targa
  1. Whats your story?
    By super9064 in forum General Info
    Last Post: 03-23-2019, 07:11 AM
  2. Whats this contact?
    Last Post: 11-25-2008, 06:41 PM
  3. Whats it worth
    By donzi in forum General Info
    Last Post: 07-08-2008, 05:18 PM
  4. Whats this part
    By joetiii in forum Technical Info
    Last Post: 04-09-2007, 12:57 PM
  5. Whats Going On in Monterey
    By boxster03 in forum General Info
    Last Post: 08-24-2005, 11:21 AM
