Thread: 67S aluminum or mag fan and fan housing? carb intakes aluminum or mag?
    Senior Member earlyaircooled's Avatar
    Jun 2008
    Portland, OR
    have a 67S made in completed 6-14-67 I've gathered my original engine parts for a rebuild and I'm missing the intakes and the fan and fan housing. I was wondering on each of the three parts fan, fan housing, intakes, do I need magnesium or aluminum, what is original for my car.
    Thank you
    Manifolds are mag ,I have a set and will take a pic.
    Jeff H.
    72 911
    914-6 GT
    911S manifolds have ports that match the intake ports in the "S" heads which are 36mm vs. 32mm for the Normal 911.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Jun 2008
    Portland, OR
    I restored a 66, 911 this year and it had aluminum intakes, All the other stuff on my 67 is aluminum, are you sure the intakes are suppose to magnesium?
    Oct 2010
    Southern Ca.
    Every original '67 I've seen has had a magnesium fan housing .
    May 2006
    CT
    '67 can have either a sand cast magnesium alternator housing or a die cast magnesium housing.
    This summary should help
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  1. Carb manifold material - Mag or Aluminum
    By X-Faktory in forum Technical Info
    Last Post: 11-03-2012, 04:16 AM
  2. FS aluminum SWB fan housing
    By edmayo in forum For Sale: 911 Parts
    Last Post: 03-04-2012, 05:59 PM
  3. FS: Carb intakes
    Last Post: 02-04-2011, 07:12 AM
  4. WTB: '65-67 Aluminum 901 Engine Fan Housing
    Last Post: 10-19-2006, 02:25 PM
  5. eBay - Aluminum Fan Housing + other parts
    Last Post: 09-27-2006, 06:19 AM
