Thread: Floor gas pedal repair in a 71?
    Unfortunately I have to replace the part of the floor panel where the accelerator pedal goes, if someone can help me with some pictures it will be of great,since I dont know if the screws should be welded from the bottom up or a nut on the bottom and screw from the top?
    Thanks.
    The pedal is held in with two 6mm screws. Weld the nuts to the outside of the floor and undercoat over them.
    -Marco
    TLG Auto: Website
    Aug 2011
    New York
    Is this the section?
    Yes Sr. Great picture. If you have a picture from the other side it be great! Thank you.
  1. Clutch pedal interacting with brake pedal
    By POS in forum Technical Info
    Last Post: 11-30-2012, 03:05 PM
  2. FS: Gas Pedal
    Last Post: 05-13-2012, 07:37 AM
  3. WTB: OE pedal board and floor board for 65-68 cpe
    Last Post: 04-06-2012, 07:53 PM
  4. Floor pan repair in Chicago
    By Zuffenhausen in forum Technical Info
    Last Post: 01-16-2010, 06:42 AM
  5. 69-73 pedal cluster, forward floor, wheelwell sheetmetal
    Last Post: 09-14-2009, 05:07 AM
