Results 1 to 10 of 12
Thread: Seats - what am I missing?
    I've been lurking for a while now, soaking up all the great information but something has got me stumped.
    I'm trying to put the correct seats into my '72 Coupe and they won't fit. I've checked exploded parts diagrams etc. etc. but couldn't find the answer so I thought I'd post here instead and see if you guys can help me out.
    Thanks in advance, hopefully it's something simple!
    Hi Maurice,
    Easy answer: you are missing the seat base brackets. Send me your email and I'll send you a close up pic of what I mean. You need 2 of them. One for each side. These are fitted only on the side of the door.
    Erick
    Thanks Erick,
    Does anyone know the part number and if there's a source for these parts in UK/Europe or am I going to have to find second-hand?
    Maurice
    Senior Member ThomasTe's Avatar
    Jan 2005
    Denmark, Europe
    Seat base brackets are NLA. Part number 901.521.016.00 for -1972.
    There is one for sale here. Maybe seller has another one for the other side, too:
    http://www.ebay.de/itm/Porsche-911-F...item20cda15666
    Here is another from the same seller:
    http://www.ebay.de/itm/Porsche-911-F...item20cda156d4
    Thomas
    1973 911S Targa
    Thanks for the photo Erick - nice seats!
    Thanks Thomas - I have sent the vendor a message to see if he has a pair for an E series 911.
    To clarify, my car is an E-series and I was a little confused if this bracket changed at all from 72 E to 73 F-series? Some sources gave the impression it did???
    Nov 2003
    Santa Monica CA
    The seat brackets also have floating threads so you can not miss the line up of the screws. keep all screws loose until all screws are threaded, then tighten all. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Jun 2012
    London, Ontario, Canada
    Nineapart has the right seat brackets, I bought mine there when I put the right seats in and dumped the old 80's recaros.
    Early 911S Registry # 2395
    Jan 2007
    North of the GG Bridge
    The seat tilt adjusters are suppose to be located on the outside (door side) when seats are installed; so you can reach them easily. It looks like your seat back is mounted to the wrong seat base. The locking seat base mechanism is to the tunnel side and the seat back adjustments are to the door side. The seat in the photo (passenger side) has all the controls on the same side.
    +1 indeed the locking notches are on the tunnel side. the seat pictured is for the passenger side but the seat back tilt mechanism (black hinge) is for the driver side. you need to switch the hinges and find the missing parts(the 2 outer rails) and your done.
    Quote Originally Posted by 68911+1 View Post
    Richard aka le Zookeeper
    early reg #1128
    early reg #1128
  1. 912 ID tag gone missing...
    By racer9007 in forum General Info
    Last Post: 04-18-2013, 04:35 AM
  2. What am I missing here ?
    By Mrzoop in forum General Info
    Last Post: 09-04-2012, 08:17 AM
  3. HCT kit, anything missing?
    Last Post: 03-10-2008, 01:26 PM
  4. What am I missing here?
    By Max (SD) in forum General Info
    Last Post: 05-12-2005, 01:29 PM
