Thread: Early Engine Grill Question
    Jul 2011
    Chicago Area
    This engine grill on Ebay looks like it has been modified with holes drilled through where t-bolts should be but seller insists it is not modified. Is this a non-modified grill? http://www.ebay.com/itm/Porsche-911-...sories&vxp=mtr
    Mike Fitton # 2071
    2018 911S Carrera White
    This is a 3 bar grill for 68.5-69. It does not appear to be modified. The top hole, or top plate when mounted, is larger than the bottom hole.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Senior Member Scotty B's Avatar
    Jul 2012
    Charles City Va
    the feet on the underside contained a captured bolt. When the bolt gets rusty or otherwise f-ed up, the easiest way to fix is the get the bolt out, drill all the way through and put a bolt in from the top side. I've had to do this before and am doing it on my 73 as the bolts snapped when I tried to remove the nuts ( rust ). I use s.s. button head allens painted semi gloss black. They give a really clean " could have been factory " look. The only other option is to bend the " feet " enough to worm a new bolt in there, then rebend back to the original location. This will almost always crack the finish
    1973 911 RSR clone..... to be
    "And pretty soon you're grabbing gears like they are ten thousand dollar bills."
    http://www.kahikocustoms.com/auto-projects
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    ...and it has been painted black. The ribs should be unpainted.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
  1. Question on Correct engine Grill for '74 US Carrera
    By rmfent in forum Other Porsche Passions
    Last Post: 01-24-2013, 05:18 PM
  2. Question on Correct engine Grill for '74 US Carrera
    By rmfent in forum Technical Info
    Last Post: 01-24-2013, 01:16 PM
  3. odd engine grill question
    By robmog in forum Technical Info
    Last Post: 08-01-2011, 06:12 AM
  4. engine grill refinish experience/question
    By jkolesa in forum Technical Info
    Last Post: 03-13-2009, 03:34 PM
