Results 1 to 10 of 17
Thread: Seeking experiences with ignition advance, 2.7 RS spec motor
    I'm curious what sort of maximum ignition advance any of you with similar setups are running.
    I have about 25k miles on a 2.7 RS spec motor, PMO's, Elgin mod-S cams, 9.2:1 CR. The car is raced a few times a year, sees ambient temps from 40° to 105°, and usually runs on a blend of 91 street and 95 or 100 (when it's hot) race gas. Plugs are NGK 6's. Motor runs strongly, plugs are beautiful, distributor is set to 34° max advance.
    jhtaylor
    santa barbara
    James,
    2.7 RS + 120/104 WebCams, 019 spec MFI, 9.5 CP, lots of intake head work, stock '73 S points distributor....
    Perfect plugs, no rattle even in summer @ just a hair over 36 degrees.
    Hope this helps
    Thanks Chuck, there might be 2° in my future! I assume your motor has more than a few hundred miles on it?
    jhtaylor
    santa barbara
    Thumbs up
    The '2003 2.7 rebuild has well over 60K on it......
    Same car and motor that was behind you when you showed me the way around Buttonwillow.... ...... Thanks again BTW....
    I'm at 34 with a full factory spec 2.7 RS MFI.
    Someone questioned me about why my vacuum advance was not being used on my distributor and I did not have an answer. I thought it was an emissions thing that the hot rodders did away with, but this guy mentioned something about vacuum advance improving throttle response.
    Can anyone shed light on the issue for me?
    Max, I don't think your car ever had a vacuum advance.With few exceptions among the early cars, the vacuum retarded the timing rather than advancing it. It was an emissions/economy thing. Not sure why a bit less advance would help throttle response. While you are here, what is your timing? Jim
    jhtaylor
    santa barbara
    Sorry, I don't have that information.
    The motor is built on a 7R case from 1974. The distributor is ???? It has a vacuum canister on it. The port is just open to ambient. What you say reinforces what I thought at the time.
    Port Macquarie, Australia
    Mine's factory 8.5:1 on webers. 36° total advance on a re-graphed distributor (for 98RON)...
    John Forcier
    EarlyS #1987
    Restoration Saga
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    Max, your dizzy has vac retard, which is not necessary.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
  1. FS: 2.7 RS spec motor and 915
    By xpensivewino in forum For Sale: 911 Parts
    Last Post: 06-23-2013, 04:16 PM
  2. Plotted my Ignition Advance, Comments?
    By B D in forum Technical Info
    Last Post: 10-09-2011, 09:03 AM
  3. WTB 2.7 RS Spec Motor
    By Todsimpson in forum For Sale: 911 Parts
    Last Post: 08-11-2011, 02:45 PM
  4. Replies: 0
    Last Post: 11-15-2010, 07:53 AM
  5. 69T with 2.2S spec Motor
    By gruen911 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-04-2006, 07:10 AM
