Results 1 to 2 of 2
Thread: Front when studs
    Junior Member
    Apr 2012
    San Diego, CA
    Front when studs
    I have the wheel studs out of the front hubs. There is some rust. Any suggestions on what I should do if anything before I reassemble. Car is a 70s. Thanks
    Do you mean you pressed the studs out of the aluminum hub, and now you see that the studs are rusty ? I would clean the rust off, apply anti-seize, and press them back in.
  1. WTB 66 mm Wheel Studs
    By RW7810 in forum For Sale: 911 Parts
    Last Post: 07-13-2012, 10:28 AM
  2. ARP Head Studs
    By demo in forum General Info
    Last Post: 05-13-2008, 10:19 PM
  3. Wheel Studs
    By CamBiscuit in forum Technical Info
    Last Post: 03-28-2008, 07:50 PM
  4. Which Wheel Studs??
    By larry47us in forum Technical Info
    Last Post: 05-02-2005, 06:05 PM
  5. Exhaust studs
    By Spud in forum Technical Info
    Last Post: 03-13-2003, 12:14 PM
