Thread: Braid 7R offset question.
    Pelican and maybe others are now selling a 15" x 7" Fuchs look-alike wheel by Braid which appears likely to appeal to many. Importantly, it is available in a custom offset. I asked my question there but thought I'd raise it here as it may be of interest to some of you.
    To run 225's at the rear of an early narrow body no flare car many run the 7R 49mm offset wheel together with an adapter, usually near 15mm, to "undo" much of the increased offset. So why not just order a set of these Braids with 49mm minus 15mm or 34mm offset to begin with? Anyone see anything wrong with this?
    jhtaylor
    santa barbara
    May 2005
    Oroville, CA
    Sounds like a good idea. But how will it happen? Will they add the 15mm to the thickness of the pads? If so you will need longer studs (the most work in a wider track IMHO). If they counter sink the lug holes so you can use the stock studs, you will loose the look of the original wheel that they spent so much effort to obtain. Either way, it would be nice to have a bolt on application.
    H
    Senior Member mrgreenjeans's Avatar
    Nord Stern Region of PCA....west coast side of Region
    Anyone know if these Braid wheels are Forged or Cast ?
    Saw their clip on a you-tube segment once, but do not remember if this question came up ????
    They emphasized the deal they were made for off road rallyes and were a tough wheel, but can a super strong wheel that bends not cracks and breaks like a cast wheel , be accomplished without heat and pressure / forging ?
    Best Regards,
    mrgreenjeans
    member # 1503
    -'68 -912 Red
    -'74 -914-2.0 litre - Sunflower
    -'82/83 -944 -M404 - Guards Red
    -'84 -944 -M456 - Guards Red -Weissach Prep. -H52
    -'84 -944 -M456 - Zermatt Silver
    -'84 -944 -M404 - Sunroof Delete - Ruby Red
    -'85.2 - 944 -M456 -Zermatt / Sport Purposes
    -'86 -944 -R74 Spt.Touring Pkg - White/Burgandy
    -'88 -944 - Jubilee Ltd. Ed. -Satin Black Met/Grey Plaid
    -'88 -911 - Tourist Delivery -Venetian Blue
    -'89 -944 Turbo M030 - Satin Black Met.
    May 2005
    Oroville, CA
    They are cast. Except the lip.... The wide ones have a rolled lip welded on the cast back. At least the ones that I have seen.
    H
    Port Macquarie, Australia
    Quote Originally Posted by Harvey Weidman View Post
    H
    Yep. A mate over here experimented with anodizing Braids but only the lip works - too much silicone in the centre area indicates a cast piece. He settled for paint. Still great looking wheels though.
    John Forcier
    EarlyS #1987
    Restoration Saga
  1. Wheel Offsets for 2.8 RSR and Braid BZ Wheels 9 and 11 x 15
    By ducatithunder in forum Technical Info
    Last Post: 10-03-2014, 06:01 PM
  2. FS: NIB 15x11 Braid/Fuch rims
    By Jimmy18E in forum For Sale: 911 Parts
    Last Post: 09-08-2013, 06:51 PM
  3. Replies: 3
    Last Post: 05-05-2010, 02:42 PM
  4. BBS 7s and 9s 930 offset
    By mjmoran in forum For Sale: 911 Parts
    Last Post: 10-24-2008, 04:39 PM
  5. Source for cloth braid oil breather line?
    By Cornpanzer in forum Technical Info
    Last Post: 08-29-2008, 01:00 PM
