Thread: Clutch pedal interacting with brake pedal
    I haven't looked into it yet, but if I release the clutch pedal while trying to depress the brake pedal, sometime the two forces oppose each other and the brake pedal won't want to go down all the way. First time this happened I thought I was going to rear end the guy in front of me, but now I just keep clutch in while braking. Once stopped, I can release both.
    Common issue? Is there a faulty spring in there that can cause this? I'm wondering what i need to order prior to disassembly.
    - Brian
    1966 Mercedes 250SE Cab
    Commonly a problem with worn out bushes as the two shafts are co-axial and bush wear allows the shafts move relative to each other and then the whole thing binds up.
    Pedal Boxes and Shifters are two of the most badly negelected areas on 911s.
    Feb 2010
    San Francisco, CA
    Time to re-bush the old pedal box. Cheap and quick fix for about $20 if you do it yourself.
    Make sure you have a replacement roll pin for the clutch pedal (I believe it's on that side).
    kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Thank you!
    - Brian
  1. Replies: 3
    Last Post: 04-22-2012, 06:07 PM
  2. NEEDED Clutch/Brake pedal assembly
    By WCB4 in forum For Sale: 911 Parts
    Last Post: 12-06-2011, 02:20 AM
  3. Swap from 901 to 915 - clutch pedal shaft
    By lkadams in forum Technical Info
    Last Post: 08-30-2010, 11:08 AM
  4. FS: Clutch pedal clevis
    Last Post: 10-25-2009, 08:45 AM
  5. WTB: Clutch pedal stop
    By joetiii in forum For Sale: 911 Parts
    Last Post: 11-04-2006, 08:26 AM
