Results 1 to 7 of 7
Thread: Backspace question, early Fuchs
    The backspace for early 6, 7 and 8 inch Fuchs wheels is said to be 112mm on a nice Rennline chart widely circulated, and on what looks like a page from an early factory manual as well. Both have appeared dozens of times over the years here and elsewhere. But when I measure my 6's and 7's, I get 121mm. Are we dealing here with a typo endlessly repeated, or is there something about this I don't understand?
    jhtaylor
    santa barbara
    Jan 2011
    DFW TX
    Measured from the bead seat?
    Jan 2003
    UK
    I think that whoever compiled the Rennlist table (Sherwood Lee ?) calculated the backspace figures using the Factory's offset (ET) figures & (incorrectly) the rim widths - rather than the overall width of the wheels.
    The formula used to determine a wheel's offset is:
    ET = backspace - 1/2 overall width of the wheel
    So, for example it's known that the offset for a 6x15" Fuchs is 36mm & using the formula above (but incorrectly using half the rim width) we get:
    36 = x - 76 (half the rim width in mm)
    Thus arriving at a backspace of 112mm
    I don't have a 6in Fuchs to hand but if we say the overall width of the wheel is 6.75in (approx 172mm) - using the formula correctly we get:
    36 = x - 86 (half the overall width in mm)
    - backspace (x) is now 122mm
    Andy
    Early 911S Reg #753
    R Gruppe #105
    When I measure (pad up to plane of wheel edge) I get 121. But 122 suits me just fine. Glad to know that most of the published charts are wrong.
    jhtaylor
    santa barbara
    May 2005
    Oroville, CA
    That chart has been a problem since it was made. I think Andy explains it well how the numbers were misrepresented..
    The back space is about 4 3/4 on most of the models. It does vary by the thickness of the edge as that thickness varies by up to .080 ~2mm depending on what series wheel that you are measuring.
    The exception that I work with all the time is the 9&11s. Their back space is a little bigger, usually about 4 7/8. And the 7Rs are about 5 3/4.
    Of course the 944 16s are a whole other bag.
    Learning back space, front space and how to figure offset is the basis for finding wheels that fit.
    H
    Jun 2012
    Northern Ca
    thanks for bringing it up James.... I'd done the same as you and did actual measurement with a straight edge and it had me scratching my head over the chart.
    kj
    73 E Targa
    Thanks all. Backspace and offset are confusing enough without throwing some bad data in!
    jhtaylor
    santa barbara
  1. Replies: 4
    Last Post: 05-30-2013, 06:42 PM
  2. Another Fuchs question
    By motogman in forum Technical Info
    Last Post: 06-05-2012, 10:25 AM
  3. Steelie Backspace Data
    By 50/50 in forum Technical Info
    Last Post: 09-20-2010, 08:26 AM
  4. 5.5 fuchs question
    By 911quest in forum Technical Info
    Last Post: 12-11-2008, 08:41 PM
  5. Will 6x15 with 4" backspace fit a 69?
    By obrut in forum Technical Info
    Last Post: 07-18-2007, 02:23 PM
